Designing a Switched Mode Regulator for 48V 40A Battery ROV Applications
285 12
How can I convert a 48V battery supply down to 12V at about 12A for an ROV without designing a custom switched-mode regulator?
Use an off-the-shelf 48V-to-12V DC-DC converter rather than trying to build a custom SMPS, because a 2000W switching supply is a major project and SMPS design/construction is not beginner-friendly or especially reliable for an ROV [#21670168][#21670169][#21670174] For a 48V input and 12V, 12A output, one suggested solution is the Vicor V48B12C250B, which provides 12V at 21A and costs about $168 [#21670173] If EMI on the 48V bus is a concern, use the Vicor FIAM filter with it [#21670173] Another option mentioned is the Linear Technology LTM8027, which operates up to 60V and outputs 4A; several can be paralleled with about 0.1 ohm series resistors for current sharing, then optimized in LTSpice to ensure >12A under worst-case conditions [#21670172]
  • #1 21670162
    Amr Awny
  • #2 21670163
    Mark Harrington
  • #3 21670164
    Amr Awny
  • #4 21670165
    Cody Gass
  • #5 21670166
    Amr Awny
  • #6 21670167
    Mark Harrington
  • Recommend off-the-shelf supply and clarify output voltage
    #7 21670168
    DAVID CUTHBERT
  • #8 21670169
    Cody Gass
  • #9 21670170
    Mark Harrington
  • #10 21670171
    Amr Awny
  • Paralleling LTM8027 modules with 0.1 ohm ballast resistors
    #11 21670172
    DAVID CUTHBERT
  • Vicor V48B12C250B and FIAM filter recommendation
    #12 21670173
    DAVID CUTHBERT
  • #13 21670174
    Garth Wilson
The discussion focuses on designing a switched mode power supply (SMPS) to regulate a 48V battery source for a remotely operated underwater vehicle (ROV) application, specifically stepping down to 12V at 12A to power motors and bilge pumps. The original poster needs a regulator to convert 48V input to 12V output with sufficient current capacity. Several contributors recommend using off-the-shelf DC-DC converters due to the complexity, cost, and reliability challenges of designing a high-current (up to 40A) SMPS from scratch. Suggested solutions include paralleling multiple Linear Technology LTM8027 uModule regulators (each rated for 60V input and 4A output) with series resistors to share load current, and using Vicor Maxi, Mini, or Micro series DC-DC converters, specifically the Vicor V48B12C250B model, which provides 12V at 21A output and includes options for EMI filtering with Vicor FIAM filters. The importance of proper PCB layout and design to handle high di/dt and EMI in SMPS is emphasized. Battery capacity and current draw considerations for underwater operation are also noted.
TL;DR: For 48V ROV builds, step down to 10–12V using proven modules; a "2000 watt switching power supply is a major project" best bought off‑the‑shelf. This FAQ guides parts choices, sizing, and EMI control. [Elektroda, DAVID CUTHBERT, post #21670168]
Why it matters: Reliable power keeps thrusters and pumps running under pressure without burning time or budget.
What is an ROV and why are we using a 48V battery?
An ROV is a remotely operated underwater vehicle. The competition mandates a 48V battery, so your power system starts at 48V and must feed lower‑voltage loads. [Elektroda, Amr Awny, post #21670164]
Do I really need a regulator if my source is a 48V battery?
Yes. Your bilge pumps need 10V, and two run together. A regulator or dedicated DC‑DC stage is required to supply that rail safely. [Elektroda, Amr Awny, post #21670166]
What output spec do my motors need from the regulator?
You stated a 48V to 12V conversion, delivering about 12A to the motors. Size the converter and wiring for continuous 12A at 12V. [Elektroda, Amr Awny, post #21670171]
Can I build a 48V to 10–12V SMPS myself?
It’s possible but not recommended for your first design. As one expert noted, a 2000W SMPS is a major project; reliability matters underwater. [Elektroda, DAVID CUTHBERT, post #21670168]
What off‑the‑shelf 48V→12V module fits 12A or more?
Vicor’s V48B12C250B outputs 12V at 21A, covering your 12A requirement with headroom. Add a Vicor FIAM filter to tame bus EMI. [Elektroda, DAVID CUTHBERT, post #21670173]
How do I cut EMI on the 48V line feeding my converters?
Place an input EMI filter on the 48V bus. The suggested Vicor FIAM filter is designed for this and pairs with their DC‑DC modules. [Elektroda, DAVID CUTHBERT, post #21670173]
Can I parallel smaller regulators to reach 12A?
Yes. The LTM8027 handles up to 60V in and 4A out. Parallel several with small series resistors (≈0.1Ω) and verify sharing in LTspice. [Elektroda, DAVID CUTHBERT, post #21670172]
Why is SMPS layout such a big deal?
High di/dt currents make layout critical. "SMPS design and construction is not for beginners" because poor layout causes instability and noise. [Elektroda, Garth Wilson, post #21670174]
How much current could the system pull at full thrust?
If each motor draws about 25A, two motors together mean around 50A from the battery. Size conductors, fusing, and connectors accordingly. [Elektroda, Mark Harrington, post #21670167]
What should I do about the 10V bilge pumps?
Provide a dedicated 10V buck stage from 48V or from 12V, sized for both pumps’ combined current. Keep it isolated from motor spikes. [Elektroda, Amr Awny, post #21670166]
Quick how‑to: pick a 48V→12V converter for my ROV
  1. Define outputs: 12V/≥12A for motors; 10V rail for pumps.
  2. Select module: e.g., V48B12C250B for 12V/21A headroom.
  3. Add input filter (FIAM), then validate under load on the bench before wet tests. [Elektroda, DAVID CUTHBERT, post #21670173]
What if I still want to design a custom multi‑module solution?
Model it first. Parallel LTM8027 uModules with small ballast resistors, tune values in LTspice, and confirm worst‑case current sharing margins. [Elektroda, DAVID CUTHBERT, post #21670172]
Is there a failure mode I should plan for early?
Watch for poor current sharing when paralleling modules. Mismatch can overload one regulator. Ballast resistors and simulation mitigate this risk. [Elektroda, DAVID CUTHBERT, post #21670172]
Why not overspec everything and be done?
Overspec costs and weight add up fast. A 21A, 12V module already provides margin over the requested 12A without unnecessary bulk. [Elektroda, DAVID CUTHBERT, post #21670173]
Who benefits most from off‑the‑shelf converters here?
Student or competition ROV teams gain reliability and speed. You avoid the steep SMPS learning curve and focus on mission tasks. [Elektroda, DAVID CUTHBERT, post #21670168]
Will layout still matter if I buy modules?
Yes. Keep short, wide high‑current paths and clean returns. Even with modules, layout discipline keeps noise and heat under control. [Elektroda, Garth Wilson, post #21670174]
