I Plan to design a Plug-In module for ACE (Artificial car environment), this module will be a switch mode power supply .The Vin (12V-48V) nominal range which will be from a Vbatt (battery) to the SMPS (IC) The output voltage range has to be (Vout 0-40V), with current limit upto 20A. I have been searching for a while now for SMPS (IC, Controller) From Ltspice, Texas Instruments. I Found a few, but I am not sure if they will suit my application before I place a order. There is also a ECU (load) (which will be connected via CAN) to the micro-controller will have loads that will draw currents upto 20A (approx) Micro-controller (to control the switch freq, en, wdt ,rst ) for the Switch IC Any suggestions Regards |
Bhargav Jani
Bhargav Jani
