Career Outlook for Board Design Engineers in India Over the Next 10 Years
300 11
Will board design engineering still be a viable career in India over the next 10 years, or will PCBs become obsolete?
Board design engineering should remain a viable career over the next 10 years; PCBs are not expected to disappear, even if some design tasks become more automated [#21670247][#21670249] Most products will still need multiple ICs plus capacitors, resistors, magnetics, and other components on a PCB, because one silicon process cannot cover everything from power conversion and audio to memory, display, camera, and RF [#21670247] A likely change is fewer dedicated PCB designers because improved software and autorouters may take over part of the layout work, with some of that responsibility shifting to the EE who designs the circuit [#21670247] One reply also notes that the PCB industry has kept growing as more function gets integrated onto each board rather than eliminating the board itself [#21670253] So the main career risk is not obsolescence, but the need to broaden your skills and move closer to full circuit-level design if you want the best stability [#21670247]
  • Future outlook for board design engineers in India
    #1 21670244
    Slasher SR
  • #2 21670245
    DAVID CUTHBERT
  • #3 21670246
    Slasher SR
  • PCB design remains essential despite more integration
    #4 21670247
    DAVID CUTHBERT
  • PCB design unlikely to be replaced by ASICs
    #5 21670248
    Slasher SR
  • #6 21670249
    DAVID CUTHBERT
  • #7 21670250
    Slasher SR
  • #8 21670251
    Ahsanul Haque
  • #9 21670252
    EEWeb
  • More integration still drives PCB demand
    #10 21670253
    Garth Wilson
  • Seeking resources to update PCB design skills
    #11 21670254
    Ruben Proost
  • High-speed digital design resources and references
    #12 21670255
    Garth Wilson
The discussion addresses the career outlook for board design engineers in India over the next decade, focusing on the relevance and future of PCB design amid rapid advancements in semiconductor technologies such as VLSI, ASICs, and FPGAs. It is widely agreed that PCBs will remain essential components in electronic devices, as no device currently exists without a PCB substrate. Despite increasing integration in chips, multiple ICs and discrete components like capacitors, resistors, and magnetics still require PCB assembly. While PCB design may evolve with improved autorouting software potentially reducing the number of designers, the role will likely shift towards electrical engineers who also design circuits. The PCB industry is expected to grow, with boards becoming thinner and more rigid. For career stability, expanding skills into high-speed design, FPGA programming, and embedded coding (e.g., in C) is recommended. Resources for updating knowledge in high-speed and multilayer PCB design include Dr. Howard Johnson’s publications and online technical notes. The consensus is that PCB design will not become obsolete but will require continuous skill enhancement aligned with industry trends.
TL;DR: Over the last 20–25 years, “the PCB industry had actually been growing,” and that trend supports strong 10‑year prospects for board designers. [Elektroda, Garth Wilson, post #21670253]
Why it matters: If you’re weighing a switch to VLSI/ASIC, this FAQ clarifies long‑term demand, skills, and tools for PCB/board engineers in India and beyond.
What’s the 10‑year career outlook for board design engineers in India?
Healthy. Experienced engineers report PCBs won’t be replaced, and integration increases board functionality rather than eliminating boards. The market has grown despite prior predictions. Stay current and move up the value chain to remain competitive. [Elektroda, Garth Wilson, post #21670253]
Will a single chip replace the entire PCB soon?
No. One silicon process rarely handles power conversion, audio, memory, display, camera, tactile input, and RF together. Products still need multiple ICs and passives on a PCB. “I don’t see PCBs going away.” [Elektroda, DAVID CUTHBERT, post #21670247]
Do stacked or SiP packages eliminate PCBs?
No. Stacked ICs sit on a PCB substrate inside the package. The final product still mounts components on a board for power, I/O, and system integration. [Elektroda, DAVID CUTHBERT, post #21670247]
What skills help future‑proof a PCB/board career?
Add system‑level design, high‑speed digital, power integrity, and mixed‑signal layout. Pair PCB design with circuit design so you can “move up the food chain.” [Elektroda, DAVID CUTHBERT, post #21670247]
Is high‑speed design worth specializing in?
Yes. High‑speed skills remain valuable across MSP430, ARM, and x86 platforms. They transfer to modern buses and interfaces used in consumer and industrial products. [Elektroda, Slasher SR, post #21670248]
Will autorouters take my job?
Expect productivity gains but not full replacement yet. Engineers note autorouters struggle with quality on digital and mixed‑signal boards. That creates demand for skilled designers. [Elektroda, DAVID CUTHBERT, post #21670247]
What’s an edge case where automation fails?
Mixed‑signal routing. Automated tools often mishandle return paths, isolation, and sensitive nodes. Manual constraint‑driven routing still wins here. [Elektroda, DAVID CUTHBERT, post #21670247]
Are PCBs becoming obsolete as devices shrink?
No. Smaller devices increase density, but boards continue to host more function per area. Industry experience shows growth, not disappearance, with greater integration. [Elektroda, Garth Wilson, post #21670253]
What about costs for small production runs?
Tool‑up charges can make low quantities expensive. This remains a barrier for prototyping and niche products, even as capabilities improve. [Elektroda, Garth Wilson, post #21670253]
Should I pivot to VLSI/ASIC or stay in boards?
Both paths can thrive. If you enjoy boards, deepen system design and power skills. Cross‑skill with firmware or FPGA to expand roles and resilience. [Elektroda, DAVID CUTHBERT, post #21670247]
What is VLSI, in simple terms?
VLSI means Very‑Large‑Scale Integration: packing many transistors and functions into one chip. It complements boards rather than replacing them. [Elektroda, DAVID CUTHBERT, post #21670247]
What is an FPGA, and why should a board engineer learn it?
An FPGA is a reconfigurable logic chip. Knowing basic FPGA design helps partition systems, set constraints, and design robust high‑speed interfaces on boards. [Elektroda, DAVID CUTHBERT, post #21670247]
What is a PCB autorouter?
It’s software that automatically routes traces based on rules. Experts note it still performs poorly for complex digital or mixed‑signal work. [Elektroda, DAVID CUTHBERT, post #21670247]
What is high‑speed design?
It focuses on signal integrity and timing when edge rates or frequencies make traces behave like transmission lines. It’s core for modern boards. [Elektroda, Slasher SR, post #21670248]
How do I update my high‑speed PCB knowledge quickly?
Study Dr. Howard Johnson’s materials and high‑speed design book for theory and pitfalls. Complement with application notes and targeted practice. [Elektroda, Garth Wilson, post #21670255]
How can I future‑proof my PCB career in three steps?
  1. Own the schematic and system architecture, not just layout.
  2. Master power delivery, return paths, and mixed‑signal partitioning.
  3. Use automation, but guide it with constraints and reviews. [Elektroda, DAVID CUTHBERT, post #21670247]
