I drew up a schematic that shows location A and B which are 400 feet apart. I would like to run 12 volts DC in one direction and 120 volt AC in the other direction on the same wire, but not at the same time of course. The switch when on will hold the two relays closed allowing AC to flow from location B to location A when the switch is turned off both relays will open and connect the normally open contacts in both relays allowing the 12 volts from the battery to flow from location A to Location B. I added a fuse at battery in case. Will this setup work as it looks to me that it will work?
John Fiebiger
John Fiebiger
