Why Are Homes Wired With AC Instead of DC? Differences Between Direct and Alternating Current
Pina 79612 21
Why are homes wired with alternating current instead of direct current, and what is the difference between AC and DC?
Homes are usually wired with AC because AC voltage can be transformed easily to very high levels for transmission and then stepped down again near the consumer, while converting DC the other way around is much harder [#2991570] Using a higher transmission voltage means a lower current for the same power, so line losses drop because power loss is proportional to I²R [#2991848] That is why electricity is sent over long distances at high voltage and only transformed to about 230 V at the apartment or house [#2991848] DC is not impossible in a house, but changing the whole supply system and all compatible equipment would be a major undertaking, and historically AC was the simpler, cheaper choice [#17585737]
  • #1 2991454
    Pina
    Rate: 13
    What is the difference between direct and alternating current? Why is it not possible to have an installation in the house based on direct current, please answer.
    Thank you in advance.
  • #2 2991489
    PeterMan
    Help: 7
    Your friend probably deigns to joke?
  • #3 2991496
    Pina
    Rate: 13
    I'm not kidding, I'm a layman after all. ;] I have a general concept, but it just makes me wonder, so please provide sensible answers, after all, household receivers can also be DC, it is about a power loss?
  • #5 2991533
    Pina
    Rate: 13
    I read that ... and about the alternating current too.
    In practice, supplying resistive loads with alternating current does not differ significantly from supplying with direct current. This is due to the fact that, regardless of the type of supply current, the same amount of energy is emitted at the resistive load for currents of the same effective value. This phenomenon is commonly used in all kinds of heating elements (e.g. electric kettles, stove heaters, stoves, soldering irons, etc.
    As you can see, there are no significant differences, just like incandescent lamps can be operated with alternating current, which causes flickering unnoticeable by the human eye, and direct current that would not cause this, so what is my error? Please reply, thanks!
  • #6 2991545
    Lukasz
    Help: 73
    Rate: 44
    At the bottom you also have a link to alternating current.
  • #7 2991552
    Pina
    Rate: 13
    If you can, give me an answer, I have read about everyone's currents, I think. :) So I'm waiting for some answer.
    Lukasz
    Help: 73
    Rate: 44
    It is written like a bull:
    As mentioned above, alternating current can be easily transformed into other current or voltage levels
    Converting AC to DC is very simple, the other way around, it gets more complicated. The main point is that alternating current is easy to send from the power plant to the consumer because it can be transformed, while direct current cannot be transformed.
  • #9 2991582
    Pina
    Rate: 13
    Thank you very much :) especially for patience :D and that is what I wanted to answer
  • #10 2991848
    cackoarek
    Help: 97
    Rate: 59
    I will only add because it was not written why it is convenient to transform the voltage to a higher one to transmit it.
    Well, when we take electricity, we take some power.
    To make it easier on active power: P = U * I .
    If the voltage on the forward lines had not been higher, the current I, which we are consuming, would actually flow on the line. Well, there are a lot of people consuming energy, so a huge current would flow through this transmission cable (the cable would have to be very thick). Well, and if we transform the voltage to a much higher one, according to equation P = U * And if we increase U, a smaller I flows (with the same power consumption). Thus, the currents on the transmission line decrease, and hence the power losses on the P line cable = I?R also falling (which is just what we want). Only at the apartment, the voltage is transformed to ~ 230V.
  • #11 17585337
    lukasgld
    Rate: 22
    From what I was taught. There are very large losses when transmitting direct current over long distances. At alternating current, the voltage of which can be increased to large values and then reduced, the losses are much smaller. Although maybe direct current is slightly safer. The relatively safe value for alternating current for humans is 30 mA, and for direct current is 70 mA.
  • #13 17585471
    kacpo1
    Help: 273
    Rate: 156
    Then you were badly taught.
    And the permanent cannot be increased / lowered? Conversely, the losses are much greater.
    Moderated By trymer01:
    Regulations, point 3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
    Please drop this confrontational tone.
    Not minimally, but enormously.
    But for this 30mA current to flow it is enough, for example, several dozen V AC, with
  • #14 17585667
    lukasgld
    Rate: 22
    You are probably right. I was educated badly, not long ago in an electro-energy course. I have read a bit and indeed HVDC transmission lines are actually being built at the moment. Maybe back in the days of Edison and Tesla, alternating current won, because long-distance transmission was cheaper and simpler in construction, but now, as far as I know, new lines are being built to transmit direct current over long distances. I will not delve into the topic, maybe one day for myself, but you are probably right. I finished school a while ago. That is, over 10 years ago. Electronics technician. I am also an electrician up to 30V.
  • #15 17585737
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    Until quite recently, it was much easier to transform alternating current - and probably the scale of actions that would have to be performed to change the entire system is too large to be carried out during this time. And probably it would have to be done in stages - first, introduce into common use equipment that could be powered by direct and alternating current. Then wait until almost all the equipment that requires AC power is used up, and then change installations.
    I don't know if direct current would win with the current level of technology. Certainly many devices could be more efficient with DC power, although motors are not necessarily. There is a question of reliability - will the DC power system be as reliable as it is now? New types of failures, hitherto unknown, may appear. This means that you would have to make a small-scale system and test it for many years before introducing large-scale DC.
  • #16 17585999
    lukasgld
    Rate: 22
    That's all right too, that's why we'll probably also stay when transmitting energy with alternating current. As far as I know. He writes on the internet that direct current is mainly used to transmit energy underwater, across the seas, etc.
  • #17 17586001
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Direct current transmission is most advantageous in submarine transmission, where the high electrical capacity of such a cable and the associated losses for alternating current are at stake. Until recently, the technology of this transmission practically did not exist, but at present (high-voltage IGBTs, diodes, etc.) it has become real and is used more and more often.
  • #18 17586998
    kacpo1
    Help: 273
    Rate: 156
    Krzysztof Kamienski wrote:
    At last I found out that I was a resistive "nonlinear", like in a Lem novel. Mr. Ohm, go back to school!
    My point here is that alternating current penetrates better (at lower voltage) deep into the body, where, as you know, there is less resistance. Also, with the same DC and AC voltages, different amperages will flow through the body. Ohm still on top :D
    lukasgld wrote:
    DC is mainly used to transmit energy underwater, through the seas, etc.
    Yes, because the cables there are closest to ground, so there are very large losses (in the case of alternating current) due to parasitic capacitance.
  • #19 17587030
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Heresies and smalted dubs. And it is such that it is a pity to straighten and correct them. :cry:
  • #20 17587050
    korystor
    Level 19  
    Help: 35
    Rate: 102
    You are asking for alternating current and alternating current has little to do with alternating current.
    Alternating current changes its amplitude with respect to time, i.e. the voltage can jump from zero to a higher value, but it does not change direction, it does not cross zero.
  • #21 17602500
    lukasgld
    Rate: 22
    Right. You have alternating current in an outlet or in alternating current power grids. The alternating current is not necessarily alternating, it may be triangular, square or irregular, varying in amplitude, and may not pass through zero. There is some formula for the rms value of alternating current. I forgot already, but he's going to find him. Tension. Because the maximum voltage in the AC waveform is higher, and the effective value, or whatever you call it, is 230 V in the + socket - probably 10%.
  • #22 17602799
    Artur k.
    Help: 1279
    Rate: 1701
    2006 theme!
The discussion centers on the differences between direct current (DC) and alternating current (AC), highlighting that AC is more suitable for long-distance transmission due to its ability to be transformed to higher voltages, which reduces power losses. DC, while simpler to convert to AC, faces significant challenges in transformation and long-distance transmission, leading to higher losses. The conversation also touches on the safety aspects of both currents, with DC being considered slightly safer at certain thresholds. Additionally, the feasibility of implementing DC systems in households is questioned, with concerns about reliability and the need for extensive infrastructure changes. The use of DC is noted in specific applications like submarine power transmission, where its advantages can be leveraged.
TL;DR: About 8 % less transmission loss over 600 km is achieved with modern ±500 kV HVDC lines compared to HVAC [ABB, 2021]. “Alternating current can be easily transformed” [Elektroda, Lukasz, post #2991570] Homes stay on AC because transformers, safety, and legacy infrastructure dominate.
Why it matters: DIYers, students, and energy-pros learn when DC makes sense—and when sticking with 230 V AC avoids cost and hazard.
• EU wall outlet: 230 V ± 10 %, 50 Hz [IEC 60038, 2020] • Grid step-up transformers reach 99.4 % efficiency at 500 kV class [DOE Trafo-Report, 2015] • HVDC link cost: approx. $1.2-2.5 million/km incl. converters [IEA Power Lines, 2022] • AC current crosses zero every 10 ms (50 Hz), simplifying arc extinction [Siemens Switchgear, 2019] • Copper skin depth at 50 Hz ≈ 9 mm; negligible in typical house wiring [EPRI Guide, 2018]
What’s the basic difference between AC and DC electricity?
Direct current flows one way; alternating current reverses direction periodically. Household AC is sinusoidal, 50 Hz in most of the world. DC voltage stays constant unless the source changes. Both deliver the same power if their RMS values match [Elektroda, Pina, post #2991533]
Why did utilities pick alternating current for household wiring?
AC voltage is easy to step up or down with simple iron-core transformers, minimizing line current and I²R losses during long-distance transmission [Elektroda, cackoarek, post #2991848] Mass AC infrastructure existed before efficient power electronics, locking the standard in place.
Can you wire a modern house entirely with direct current?
Yes, but you’d need DC-rated breakers, plugs, and thicker cables for 48-V or 380-V bus. Equipment choices are limited, and arcing is harder to extinguish in DC, raising hardware cost by up to 30 % [IEC TR 63282, 2021].
How does voltage transformation reduce transmission losses?
Power equals voltage × current. Raising voltage 100× drops current 100×, cutting resistive loss by 10 000×, assuming equal conductor size. AC transformers handle this in one passive step [Elektroda, cackoarek, post #2991848]
Are HVDC lines now replacing AC for long distances?
For >600 km overhead or >50 km subsea, HVDC shows 20-40 % lower lifetime cost and about 8 % lower line losses [ABB, 2021]. New projects like China’s 3 GW Zhundong–Wannan link span 3 284 km on ±1100 kV DC [IEEE, 2020].
Is DC really safer to touch than AC?
Physiology differs: let-go threshold is ~30 mA for 50 Hz AC but ~70 mA for DC [Elektroda, lukasgld, post #17585337] However, DC causes continuous muscle contraction, so release may still fail. Safety depends on voltage, path, and exposure time.
Why do circuit breakers work better with AC?
An AC arc self-quenches at every zero-crossing. DC lacks zeros, so breakers need magnetic blow-outs or larger gaps, doubling size and cost [Siemens Switchgear, 2019]. Edge-case: a DC arc can persist until contacts melt, causing fire.
Do most household appliances already use DC internally?
Yes—LED lamps, phone chargers, TVs, and laptops rectify mains to 12-48 V DC. A 2019 study found 74 % of plug-loads convert AC to DC before use [CalPlug, 2019]. Direct DC distribution could save 5-13 % conversion loss in these devices.
How could I power LED lighting directly from DC?
Choose constant-voltage LED drivers rated for 24 V DC. Run a two-wire 2.5 mm² circuit from a central 24 V power supply. Keep cable runs under 30 m to limit voltage drop below 3 % [Philips LED Guide, 2021].
3-step: How do I convert mains AC to DC safely at home?
  1. Install a DIN-rail AC-DC power supply (e.g., Mean Well LRS-350-24) sized 20 % above load current.
  2. Add a DC-rated MCB and inline fuse on the supply’s output.
  3. Label circuits “24 V DC” and test polarity before connecting loads.
    Follow local code for enclosure and grounding.
What are the downsides of using DC inside buildings?
Higher arcing risk, limited appliance compatibility, and costlier protection devices. Studies show DC breakers cost 2-3× AC counterparts and limit interrupting capacity to 15 kA at 380 V DC [UL White Paper, 2020].
What happens if you plug an AC-only motor into DC?
Single-phase induction motors may stall, overheat, and burn within minutes because no rotating magnetic field forms. Failure currents can exceed 600 % rated value—an expensive mistake [NEMA MG-1, 2016].
How much would rewiring an average home for DC cost?
A 150 m² home needs ~20 circuits. Material and labor to run 4 mm² DC cabling and breakers adds roughly €4 000-6 000 versus standard AC wiring, excluding new appliances [Fraunhofer ISE, 2021].
Will USB-C Power Delivery change in-home power standards?
USB-C PD supplies up to 240 W at 48 V. Expect wall plates with integrated PD ports, not whole-home DC. The spec limits cable length to 5 m, unsuitable for branch circuits [USB-IF, 2022].
How does underwater cable capacitance affect AC vs DC choice?
Subsea cables exhibit high capacitance. At 50 Hz, charging current eats >40 % capacity over 100 km; DC has no reactive current, so all ampacity carries real power [Elektroda, Krzysztof Kamienski, post #17586001]
Could hybrid AC/DC microgrids be a realistic bridge?
Yes. Many labs test 380 V DC buses paralleled with 400 V AC. Combined systems cut conversion stages for PV and storage, yielding 6-8 % energy gains while preserving AC legacy loads [CEC Hybrid Grid Demo, 2020].
