How to Discharge 4.2V 1F Supercapacitor at 1.5A to Charge a 4V 1500mA Battery?
294 10
How can I use a supercapacitor to charge a 4V 1500mAh battery at 1.5A, and do I need a boost or regulator circuit?
You cannot discharge the supercapacitor straight into the 4V battery at a steady 1.5A; you need a boost or buck/boost converter plus a proper battery-charger IC, because the capacitor voltage falls as it discharges and will soon drop below the battery voltage [#21673229][#21673239] A constant-current discharge follows Uc = U0 - Ic * t / C, so the capacitor voltage drops linearly with time when you draw a fixed current [#21673239] The energy mismatch is also huge: a 4V 1500mAh battery is about 6Wh, while a 1F cap charged to 5.5V stores only about 15.1J (0.0032Wh), so you would need more than 40 such 1F/5.5V capacitors to fully charge the battery [#21673232][#21673236] One suggested approach is a charger like the LTC3558, which includes a buck/boost converter and can be programmed for the desired charge current [#21673239] If that part is not suitable, use a boost converter with the lowest possible input voltage, boost up to about 5V, and then feed a separate battery-charging IC [#21673239]
  • Capacitor energy is far too low to charge battery
    #1 21673230
    Enrico Koeck
  • Explaining supercapacitor discharge graphs for battery charging
    #2 21673229
    noneya noneya
  • #3 21673231
    noneya noneya
  • #4 21673232
    Enrico Koeck
  • #5 21673233
    noneya noneya
  • #6 21673234
    noneya noneya
  • Charging supercapacitors from a 12 V supply
    #7 21673235
    noneya noneya
  • Need more than 40 supercapacitors to charge battery
    #8 21673236
    Enrico Koeck
  • #9 21673237
    noneya noneya
  • Need to determine discharge current and voltage drop time
    #10 21673238
    noneya noneya
  • LTC3558 charger suggestion with cap voltage limits
    #11 21673239
    Enrico Koeck
The discussion addresses the challenge of discharging a 4.2V, 1F supercapacitor at 1.5A to charge a 4V, 1500mAh battery. The energy stored in the capacitor (approximately 15.1 joules or 0.0042 Wh at 5.5V peak) is significantly lower than the battery's energy capacity (6 Wh). Direct charging is impractical because the capacitor voltage drops below the battery voltage during discharge, halting current flow. To maintain charging, a DC-DC boost converter is necessary to elevate the capacitor voltage to the battery charging voltage. The capacitor voltage decreases linearly with constant current discharge, following Uc = U0 - Ic * t / C. Using multiple capacitors in series can increase voltage and capacitance (e.g., two 2.7V 3000F capacitors in series yield 5.4V at 1500F). Charging the capacitor bank requires a step-down regulator from a higher voltage source. Battery charging methods depend on battery chemistry (Li-Ion, LiFePO4, NiMH, etc.) and typically involve constant current or constant voltage charging controlled by dedicated ICs. The LTC3558 IC is recommended as a programmable buck/boost charger with an input voltage range of 4.3V to 5.5V, suitable for managing the limited usable energy from the capacitor. Boost converters must have low input voltage thresholds to utilize more capacitor energy and provide stable 4V output at the required current. Charging time is estimated by dividing battery capacity by charging current (e.g., 1.5Ah / 1A = 1.5 hours). The BCAP3000 supercapacitor from Maxwell is referenced for practical experimentation.
