How to Build a 24V DC Power Supply With Adjustable Output Using Potentiometer
408 9
How can I make an adjustable DC output from a 24 V, 0.8 A adapter using a potentiometer and passive parts?
A potentiometer voltage divider is not a good way to make a regulated adjustable supply, because the output voltage changes when you connect a load; it only works reasonably when the load resistance is much higher than the pot resistance, and even then the voltage depends on pot position and may need DVM monitoring [#21675249] If you want a real adjustable output from your 24 V adapter, use a fixed or variable linear regulator instead of a plain divider [#21675249] A small regulator kit or module that is rated to accept 24 V DC input is a cheaper option than buying a whole lab power supply [#21675251] A simple passive divider is the cheapest and simplest approach, but it is inefficient and not suitable when the load varies [#21675247][#21675249]
  • Potentiometer divider is not a suitable regulator
    #1 21675246
    Gran Ingvarsson
  • #2 21675247
    Justin Spencer Mamaradlo
  • #3 21675248
    Gran Ingvarsson
  • Potentiometer voltage shifts under load; use a regulator
    #4 21675249
    richard gabric
  • #5 21675250
    Gran Ingvarsson
  • #6 21675251
    richard gabric
  • #7 21675252
    Gran Ingvarsson
  • #8 21675253
    Gran Ingvarsson
  • #9 21675254
  • #10 21675255
    idealwriter2
The discussion centers on building a 24V DC power supply with adjustable output using a surplus 24V, 0.8A switched AC adapter and a potentiometer-based voltage divider. The main concern is the inefficiency and load-dependence of voltage dividers with passive resistors, which cause output voltage fluctuations when the load varies. It is recommended to use a variable or fixed linear voltage regulator circuit compatible with 24V input to achieve stable and adjustable output voltage. Such regulator kits are often more cost-effective and reliable than high-power variable potentiometers. The original poster expresses nostalgia for professional lab power supplies, specifically mentioning Oltronix models with current limiting features, and ultimately decides to purchase a simple 1A Oltronix lab power supply for better performance and user experience. The discussion highlights trade-offs between simplicity, cost, efficiency, and output stability in DIY adjustable DC power supplies.
