How to Interface Honeywell 4-20mA Pressure Transducer (0-200 PSI) with Arduino?
354 6
  • Ground reference mismatch causing 4–20 mA reading errors
    #1 21675371
    Simon Iversen
  • Use a DVM to verify 4-20mA loop wiring
    #2 21675372
    richard gabric
  • #3 21675373
    Simon Iversen
  • #4 21675374
    Simon Iversen
  • Need to identify the transducer model type
    #5 21675375
    richard gabric
  • #6 21675376
    Simon Iversen
  • #7 21675377
    richard gabric
The discussion addresses interfacing a Honeywell 4-20 mA pressure transducer (0-200 PSI) with an Arduino. The transducer outputs a current signal proportional to pressure, requiring conversion to voltage via a load resistor for Arduino analog input. The user connected the transducer through a 220-ohm resistor to a power supply (Cotek GE-25-12) and attempted to measure voltage across the resistor to infer current and pressure. However, voltage readings appeared negative relative to Arduino ground, which only accepts 0-5 V inputs. One suggested solution involves proper wiring and common grounding between the transducer power supply and Arduino to ensure correct voltage referencing. The maximum load resistor value depends on the supply voltage and compliance voltage of the transducer, calculated as (Vs-8)*50 ohms; for example, a 250-ohm resistor requires at least 13 V supply. Testing with a digital voltmeter in current mode before inserting the resistor is recommended to verify correct operation. The transducer model PX2EN1XX200PSCHX is identified as a sealed gage type, meaning it measures pressure relative to an internal atmospheric reference rather than absolute pressure. Correct wiring, sufficient supply voltage, and understanding the sensor type are critical for accurate pressure measurement with Arduino.
