Maximum Power Handling Capacity of 600k Potentiometer from Fan Regulator
408 6
  • #1 21676058
    Sourav Kumar
  • #2 21676059
    Kevin Angelo Ma
  • #3 21676060
    Sourav Kumar
  • #4 21676061
    Kevin Angelo Ma
  • #5 21676062
    Sourav Kumar
  • #7 21676064
    Sourav Kumar
The discussion focuses on determining the maximum power handling capacity of a 600k potentiometer used in an electronic fan regulator. The fan regulator operates at 240V AC with a power rating of 400W and is manufactured by Pretty. The potentiometer in question is identified as a B600K model. According to the datasheet referenced, the B600K potentiometer has a rated power dissipation of 0.125W. This specification is critical for further implementation and safe usage of the potentiometer extracted from a non-functional electronic fan regulator.
