#1 21677648 18 Jul 2017 09:53 tony q tony q Anonymous Post #1 21677648 18 Jul 2017 09:53 needhelp with an adustable pressure diff alarm circuit, auto use, 12v, fuel VS boost
Request for more specifications and sensor circuit reference #2 21677649 18 Jul 2017 17:31 Neil Mula Neil Mula Anonymous Request for more specifications and sensor circuit reference Post #2 21677649 18 Jul 2017 17:31 Hi Tony, Can you expound more this issue? It good to have more specifications so we can help you correctly. If you are talking industrial pressure sensor, you can browse some circuit at "www.schematics.com":http://www.schematics.comsame to this one -> http://schematics.com/project/industrial-process-pressure-sensor-platform-17133/Requires you minor modifications in order to fit it correctly to the system or application you are trying to build.Hope it helps.Best,Neil
#3 21677650 18 Jul 2017 19:43 Kevin Angelo Ma Kevin Angelo Ma Anonymous Post #3 21677650 18 Jul 2017 19:43 I think what Tony is referring Neil is this one: https://www.eeweb.com/blog/tony_q/pressure-differential-alarm
