Help with analog gauge that has non linear resistance used to control needle
714 6
  • Nonlinear resistor conversion for fuel gauge calibration
    #1 21686137
    Tipup
  • Gauge is likely linear, sender is non-linear
    #2 21686138
    David Ashton
  • Sender and gauge use 10–75 ohm range
    #3 21686139
    Tipup
  • Lookup table with linear interpolation for gauge correction
    #4 21686140
    J C Cooper
  • #5 21686141
    Tipup
  • Suggest repairing or rewinding the gauge resistor
    #6 21686142
    David Ashton
  • LUT-based conversion for non-linear fuel sensors
    #7 21686143
    emavoow
The discussion addresses the challenge of adapting a 1970s analog fuel gauge, which operates on a non-linear resistance range (10 ohms full, 73 ohms empty) from the original fuel tank sender, to work correctly with modern aftermarket senders that have different resistance characteristics (e.g., 10 ohms full, 40 ohms empty). The original gauge receives 5V regulated voltage and measures resistance to ground through the sender. The non-linearity arises from the sender's float mechanism and the wire-wound resistive element designed to compensate for irregular tank shapes. Testing showed discrepancies in gauge readings when using aftermarket senders due to differing resistance curves and voltage supply inconsistencies caused by older constant voltage regulators. Proposed solutions include digitizing the sensor output with a microcontroller to apply a lookup table or linear interpolation to convert new sender resistance values to the original gauge's expected resistance range. Alternative analog solutions are limited; mechanical repair or rewinding the resistive element to match original resistance profiles are suggested but complex. The discussion highlights the trade-offs between analog and digital correction methods for legacy automotive instrumentation.
