Calculating Inductance of Rectangular vs Circular PCB Traces with 0.5mm/1.8mm Widths
474 6
  • Use trace width as the effective radius for inductance
    #1 21678380
    Richard Fischbacher
  • PCB inductor calculator ignores track width details
    #2 21678381
    David Ashton
  • Questioning whether trace width can substitute for diameter
    #3 21678382
    Richard Fischbacher
  • PCB coil inductance formulas ignore copper thickness
    #4 21678383
    David Ashton
  • Numerical self-inductance method using coupled PCB coils
    #5 21678384
    PeterTraneus Anderson
  • Suggesting manufacturer engineering support for PCB design
    #6 21678385
    Mike Dong
  • #7 21678386
    Michael Obrecht
The discussion addresses the challenge of calculating the inductance of rectangular and circular PCB traces with specific dimensions (0.5mm/35µm and 1.8mm/35µm width/thickness). Traditional inductance formulas typically require a conductor radius, which complicates calculations for rectangular PCB traces. One approach is to approximate the conductor radius by equating the cross-sectional area of the rectangular trace to that of a circular conductor, but this method yielded results inconsistent with measurements. Alternatively, using the trace width as the effective diameter provided results closer to simulations and measurements, though a theoretical justification is sought. The inductance depends primarily on coil geometry and number of turns rather than trace thickness or width. Several online calculators and formula collections (e.g., coil32.net) offer methods incorporating track width and spacing but often omit thickness. Numerical methods involving mutual inductance between closely spaced coil copies can estimate self-inductance with high accuracy. Practical advice includes validating calculations with simulations and measurements, and considering self-capacitance and Q factor effects influenced by conductor shape. For precise measurement of low inductance values, tools like the LCR-Reader-MP are recommended. Additionally, consulting PCB manufacturers with expertise in EDA software (Allegro, POWER PCB, ORCAD, AUTO CAD, CAM350) can provide design and analysis support.
