I installed a MEMS sensor on a motor that I can control the motor speed. I'm recording the information from the sensor (x, y, z)I'm trying to compare if the MEMS sensor reading is ad the same as my motor speed. But I don't know how to convert the data from the 3 Axis MEMSFor example I set my motor speed to 28.84 RPM, I have the data from the MEMS sensor (as a X,Y,Z array)How i can convert the data to RPM or vice versa to be able to compare the reading to the actual motor speed .thanks
david azoulay
david azoulay
