What is the best way to create a PWM signal by varying capacitance using your hand? (Sensor/Antenna)
318 6
  • Use capacitance to modulate oscillator frequency
    #1 21678550
    Chris Karln
  • Use a 555 to convert frequency into PWM duty cycle
    #2 21678551
    David Ashton
  • Theremin kit or TOF sensor PWM option
    #3 21678552
    Rick Curl
  • Suggesting a microcontroller or 74HC14 alternative
    #4 21678553
    Aubrey Kagan
  • #5 21678554
    Elizabeth Simon
  • CD4093 oscillator with envelope detector and LM311 PWM
    #6 21678555
    Chris Karln
  • Frequency discriminator converts oscillator frequency to dc voltage
    #7 21678556
    PeterTraneus Anderson
The discussion addresses the challenge of generating a PWM signal controlled by hand-varying capacitance using an oscillator and converting that frequency variation into a usable PWM output for fan control via an H-bridge. Initial attempts included relaxation oscillators, 7414 Schmitt triggers, and a variable pitch oscillator inspired by Theremin circuits, which produced sine waves in a narrow high-frequency range (120-142 kHz) but were difficult to utilize directly. Suggestions included frequency division to lower the oscillator frequency to a range suitable for PWM generation, using a 555 timer triggered by the oscillator output to produce PWM with duty cycle proportional to frequency, and exploring frequency discriminator or ratio detector circuits from FM radio receivers to convert frequency changes into variable DC or PWM signals. The project constraints limited the use to primarily analog components, allowing digital inverters for oscillators but banning integrated analog-digital ICs. Various CMOS inverters (74HC14, CD40106, CD4093) were tested, with the CD4093BE combined with a 440 kΩ resistor and a small metal plate sensor yielding satisfactory results without needing a 555 timer. Alternative approaches suggested included using microcontrollers with built-in capacitive touch and PWM capabilities (e.g., PSoC4/5) or laser time-of-flight sensors with PWM output, though these may not meet analog-only constraints.
