Designing a Circuit to Measure Phase with Optical Sensor for RC Helicopter Vibration Control
354 9
How can I design an optical sensor circuit to measure the phase of a helicopter rotor and a shaker motor so I can drive them 180° out of phase?
Use a reflective optical sensor or interrupter to generate pulse timing from the rotating part, then compare those pulses with the motor timing to determine phase. For a typical 5 V optical sensor, feed the emitter LED through a resistor of about 180–220 Ω for 20 mA, connect the receiver side to 5 V and ground, and use a pull-up resistor of about 10 kΩ on the output transistor so the output provides pulses as the motor rotates [#21678583] If you use a reflective tape sensor, keep the sensor-to-tape distance within the datasheet limits and expect problems from stray light, dust, and tape condition [#21678587] A more robust optical approach is a modulated low-power laser aimed at reflective tape, with the detector placed at the end of a tube to narrow the acceptance angle and reduce stray light [#21678589][#21678591] A narrow-band optical filter matched to the laser wavelength and AC coupling after the detector can further reject ambient light; keep the detector gain low enough to avoid DC saturation [#21678591]
  • Optical sensor circuit for phase measurement
    #1 21678582
    Mark Sheldon
  • Optical sensor wiring and resistor values explained
    #2 21678583
    Elizabeth Simon
  • Stroboscope method to locate rotor imbalance
    #3 21678584
    David Ashton
  • Optical sensor chosen to avoid rotor head attachment
    #4 21678585
    Mark Sheldon
  • #5 21678586
    Mark Sheldon
  • Reflective sensor needs proper spacing and pull-up
    #6 21678587
    Elizabeth Simon
  • #7 21678588
    Conrad Mannering
  • Modulated laser and filtered detector for daylight rejection
    #8 21678589
    Richard Gabric
  • #9 21678590
    Mark Sheldon
  • Laser diode, filter, and detector selection advice
    #10 21678591
    Richard Gabric
The discussion focuses on designing a circuit to measure the phase difference between a small-scale RC helicopter and a DC motor shaker to reduce vibration by ensuring the motor operates 180 degrees out of phase with the helicopter. The original poster prefers using an optical sensor with reflective tape on the helicopter rotor due to restrictions on attaching devices to the rotor, ruling out accelerometers. Suggested approaches include using optical interrupter sensors with an interrupter disk or reflective optical sensors, noting challenges such as sensitivity to stray light and dust. Circuit design involves providing current to the LED emitter and using pull-up resistors on the phototransistor output, with component values exemplified for a 5V supply. Alternatives like Hall effect sensors with magnets are proposed for robustness against environmental interference. For improved optical sensing, a modulated low-power laser diode combined with a narrow bandpass optical filter and a detector placed at the end of a tube can enhance signal quality by reducing ambient light interference. Components such as laser diodes, laser diode driver chips, and optical filters are commercially available from suppliers like Element14, Thor Labs, and Edmund Optics. The design aims to capture phase information accurately to enable vibration cancellation through phase-shifted motor actuation.
