I need help with a student project – creating a smart nicotine inhaler.
243 9
How can I build a basic Arduino proof-of-concept for a smart nicotine inhaler that reads RFID-tagged cartridges, counts airflow use, and is discoverable over Bluetooth on an iPhone?
Use an Arduino-based prototype with an RFID reader for the cartridge tags and a separate Bluetooth module for iPhone discovery, and get each function working on its own before trying to merge the code [#21678883][#21678888] If the Bluetooth part only needs to be discoverable, search for a “Bluetooth iBeacon” module, which was suggested as a cheap starting point [#21678882] For the RFID side, search for “rfid reader arduino” tutorials and strip the example code down until it only detects and reads a tag to the serial monitor [#21678883][#21678888] Bluetooth and RFID are different technologies: RFID is typically batteryless and read by a nearby reader, while Bluetooth needs a DC power source and is better for changing data over longer range [#21678882] Alternative Bluetooth options mentioned were Simblee, which is programmed similarly to Arduino, and Cypress PSoC 4 BLE, though that may be less beginner-friendly [#21678888]
  • Component advice for RFID, Bluetooth and airflow sensing
    #1 21678880
    Benjamin Taylor
  • #2 21678881
    Conrad Mannering
  • Bluetooth iBeacon recommended over RFID
    #3 21678882
    Rick Curl
  • RFID reader needed for cartridge identification
    #4 21678883
    Elizabeth Simon
  • #5 21678884
    Benjamin Taylor
  • RFID cartridge detection and Bluetooth module search
    #6 21678885
    Benjamin Taylor
  • #7 21678886
    Conrad Mannering
  • #8 21678887
    Conrad Mannering
  • Bluetooth module options and incremental integration advice
    #9 21678888
    Elizabeth Simon
  • #10 21678889
    Conrad Mannering
A university product designer is developing a prototype for a smart nicotine inhaler that uses air to draw flavored nicotine from cartridges, similar to a Nicorette Inhalator but with added smart features. The device requires an RFID reader to detect cartridges equipped with RFID tags and a Bluetooth module to communicate with an iPhone, primarily to be discoverable via Bluetooth without needing a fully functional app. The designer has no prior experience in electronics and seeks guidance on integrating RFID and Bluetooth technologies. Responses suggest using Arduino-compatible RFID readers and Bluetooth modules such as Bluetooth iBeacon or Simblee for ease of prototyping. Combining code for RFID and Bluetooth modules is recommended to be done incrementally, starting with minimal working examples. Power management considerations for the Bluetooth module are noted, and alternative simple cartridge detection methods like binary contact switches are proposed. References to embedded microchips in printer cartridges and contactless payment card technology provide additional context for cartridge identification methods. Cypress Semiconductor’s PSoC 4 BLE with built-in Bluetooth is mentioned as a more advanced option but possibly less suitable for beginners.
