Low-Cost Efficient TI Boost IC for 5V 2A Power Supply Recommendations
384 7
  • #1 21679537
    developer xeye
  • #2 21679538
    David Ashton
  • #3 21679539
    developer xeye
  • TI Webench Power Designer for regulator selection
    #4 21679540
    Rick Curl
  • #5 21679541
    developer xeye
  • Suggesting a bench supply test for battery current limits
    #6 21679542
    Rick Curl
  • #7 21679543
    developer xeye
  • #8 21679544
    Dale Nance
A user seeks a low-cost, efficient Texas Instruments (TI) boost converter IC to design a 5V 2A power supply powered by a lithium battery. The user has tried TI's Webench Power Designer tool and tested the TPS61236 3A boost converter evaluation board but experienced unsatisfactory results, with the device failing to deliver even 1A output despite its 3A rating. Suggestions include verifying the input power source capability, as a 3A output may require over 4A input current with higher peak demands. It was recommended to test the converter with a bench power supply to isolate battery limitations. Another user shared a potential alternative boost converter module from Pololu (product 2858) as a reference.
