Generating 5V Output for PCB Using Batteries—Voltage Regulator or DC-DC Converter?
297 6
  • #1 21667359
    tomas Tomas
  • #2 21667360
    Frank Bushnell
  • Use a boost or buck DC-DC converter
    #3 21667361
    stephen Van Buskirk
  • LDO regulator option with output capacitor requirement
    #4 21667362
    Steve Lawson
  • Linear regulator heat limits at high battery voltage
    #5 21667363
    stephen Van Buskirk
  • #6 21667364
    Steve Lawson
  • Example eBay step-up and step-down modules
    #7 21667365
    Frank Bushnell
To obtain a stable 5V output from batteries for powering a PCB, the choice between a voltage regulator and a DC-DC converter depends on the battery voltage relative to 5V and the load current. If the battery voltage is below 5V, a boost (step-up) DC-DC converter is required; if above 5V, a buck (step-down) converter is appropriate. Low Dropout Regulators (LDOs) such as the MCP1702-5002E/TO or LP2950CZ-5.0 can be used if the battery voltage is slightly above 5V, but they are less efficient and dissipate excess voltage as heat, which can be problematic at higher currents or voltages. Battery voltage variability and discharge state must be considered, as LDOs require the input voltage to remain above the output voltage plus dropout voltage. DC-DC converters offer higher efficiency and better performance across varying battery voltages. Resistors can be used for simple, constant current loads but are generally inefficient. Design tools and simulation software from Texas Instruments (TI) and National Semiconductor (now part of TI) can assist in selecting appropriate DC-DC converter designs. Commercial step-up and step-down power supply modules are also readily available online for convenience.
