How to create multiple simultaneous signal sources from a single reference source?
303 11
Can I generate several independent, simultaneously adjustable sine-wave frequencies from one reference source, and should I use PLLs or another method?
Yes, but if the frequencies are unrelated you will usually need separate PLL/VCO paths for each output, with only the controller or clock generator shared between them [#21680231] PLLs are not truly fully analog internally, and wide-range VCOs with good performance are difficult, so DDS is often the better fit for multiple channels; Analog Devices even has four-channel parts such as the AD9106, and DDS can synthesize sine waves up into the 100s of MHz [#21680229] If your outputs are integer-related, a single stable oscillator or crystal followed by programmable dividers can generate multiple frequencies, including parts like the CD4059/74HC4059 and rate multipliers [#21680232] [#21680233] Another hybrid option is to generate stepped waveforms with a shift-register/resistor network and then filter them into sine waves, with a microcontroller providing accurate timing on many outputs [#21680235]
  • #1 21680228
    John Manuel
  • PLL and DDS options for multiple sine outputs
    #2 21680229
    Richard Gabric
  • #3 21680230
    John Manuel
  • Need waveform, frequency, and spectral purity details
    #4 21680231
    Richard Gabric
  • Hybrid oscillator-and-divider approach for multiple frequencies
    #5 21680232
    Aubrey Kagan
  • #6 21680233
    Aubrey Kagan
  • #7 21680234
    Ivan Lopez
  • Shift-register DAC for stepped sine generation
    #8 21680235
    David Ashton
  • #9 21680236
    Marci425 Maxwell
  • #10 21680237
    Marci425 Maxwell
  • #11 21680238
    Greg Freund
  • #12 21680239
    pradeep bhatti
The discussion addresses generating multiple simultaneous signals of different frequencies from a single reference source, focusing on fully analog methods for kHz to MHz ranges. Phase-Locked Loops (PLLs) are considered viable, though they internally use digital components and require individual Voltage Controlled Oscillators (VCOs) for each frequency unless frequencies are integer multiples of a fundamental frequency. Challenges include achieving wide frequency range and stable amplitude, often necessitating automatic gain control (AGC). Direct Digital Synthesis (DDS) is recommended for spectral purity and multi-channel output, with devices like the Analog Devices AD9106 offering four-channel DDS solutions. An alternative hybrid approach involves using a stable high-frequency oscillator (e.g., crystal oscillator) with programmable frequency dividers (such as CD4059 or 74HC4059) to derive multiple frequencies, followed by analog filtering to approximate sine waves. Additional methods include using shift registers with resistor networks to create stepped waveforms that can be filtered into sine waves. The importance of a common clock or microprocessor for programming multiple PLLs or dividers is noted. Overall, DDS and PLLs are primary solutions, with programmable dividers and analog filtering as practical analog or hybrid methods for generating multiple frequencies simultaneously from a single reference.
TL;DR: Need multiple kHz–MHz signals from one reference? DDS chips reach up to 100s of MHz; “PLLs would certainly do the job.” [Elektroda, Anonymous, post #21680229]
Why it matters: This FAQ shows builders how to fan out one stable reference into many simultaneous, tunable outputs with practical part choices and traps to avoid.
Quick-Facts
Can I use PLLs to create many simultaneous frequencies from one reference?
Yes. Use one PLL per independent frequency when outputs are not simple integer multiples. Share a common reference clock and a controller to program each loop. The VCO in each loop sets its band; wide tuning ranges are harder to stabilize. Plan loop bandwidth and filtering per channel. [Elektroda, Anonymous, post #21680231]
Do I always need a separate PLL/VCO for every output?
Not if the outputs are integer‑related. You can synthesize one high‑frequency source and divide it down to multiple channels. Otherwise, independent tuning requires separate VCOs and loops. Share the programming interface and master clock to reduce duplication. [Elektroda, Anonymous, post #21680231]
Is DDS better than PLL for multi‑channel generators?
DDS is often simpler for many channels. It creates sine waves digitally from a table and DAC, and modern parts cover up to the 100s of MHz. Multi‑channel DDS ICs such as AD9106 reduce part count. “They are used in many modern signal generators.” [Elektroda, Anonymous, post #21680229]
How can I stay (mostly) analog yet keep things simple?
Use a crystal or stable oscillator at or above your highest frequency, then add programmable dividers for each channel. Shape the square outputs into sines with filters or op‑amp stages. This “hybrid” keeps a single reference and analog outputs while avoiding many VCOs. [Elektroda, Anonymous, post #21680232]
What is a VCO, and what’s the catch?
A VCO is a voltage‑controlled oscillator used inside PLLs. It tunes frequency with a control voltage. Wide tuning ranges complicate design and degrade performance. Use amplitude leveling (AGC) if you need constant output level across the band. [Elektroda, Anonymous, post #21680231]
What is a rate multiplier, and when would I use one?
A rate multiplier outputs a fractional multiple of its input clock (e.g., N·Fin/16 for binary types). Devices like the CD4089 let you set N via pins, enabling flexible frequency steps derived from one high‑frequency clock. [Elektroda, Anonymous, post #21680233]
What do CD4059 and 74HC4059 do in this context?
They are programmable divide‑by‑N counters. CD4059 divides by 3–15999. 74HC4059 is the faster CMOS variant and takes about 18 MHz at 5 V. Use them to derive many exact frequencies from one high‑frequency source. [Elektroda, Anonymous, post #21680233]
How do I avoid a floating selector pin in my divider bank?
Add a pull‑up or pull‑down to the control pin so an unselected switch doesn’t leave it floating. A 100 kΩ resistor to VDD or ground on the first position prevents undefined states and glitches on startup. [Elektroda, Anonymous, post #21680236]
Can I get a sine wave without a DAC?
Yes. Clock a shift register with a pattern of ones and zeros, sum outputs through a resistor ladder, and filter. Equal resistors yield a triangle; tailored values approximate a stepped sine that smooths to a clean sine after RC filtering. [Elektroda, Anonymous, post #21680235]
How do I build a simple multi‑output generator from one crystal?
  1. Choose a crystal above your highest target frequency.
  2. Feed programmable dividers to create each channel frequency.
  3. Low‑pass filter or op‑amp‑shape each output into a sine as needed.
    This scales well when outputs are integer‑related. [Elektroda, Anonymous, post #21680232]
Do I need sine or square outputs for my application?
Define your load and purity requirements first. Square waves are easy after division. Sine outputs need filtering or a DDS/DAC path. If you need constant amplitude or low spurs, budget for leveling and proper filters. Ask yourself what spectral purity you need. [Elektroda, Anonymous, post #21680231]
What performance should I expect from DDS?
DDS purity depends on DAC resolution, clock quality, and output filtering. Many lab generators use DDS because it’s stable and wideband. Start with a clean reference, then filter adequately. “Sine waves are synthesized using a lookup table and DAC.” [Elektroda, Anonymous, post #21680229]
