How to Discharge a Capacitor Into a Coil Using SCR Without Latching From Charging Path?
330 9
How can I charge a capacitor from a DC supply and discharge it into a coil with an SCR without the charging current latching the SCR on?
Use a MOSFET instead of the SCR, because the SCR will latch if the charging path keeps supplying holding current. A small pass transistor could be used to disconnect the charging supply while the SCR is triggered, or you could charge from pulsed DC through a series diode so the SCR has time to turn off [#21680755] Another suggestion was to use a larger SCR with higher holding current, or reduce the gate-to-cathode resistor to desensitize it, but that was presented as a workaround rather than a clean fix [#21680757] More elaborate commutation or isolation circuits were also proposed, but they quickly made the circuit more complex than the original design [#21680757][#21680760] The thread’s consensus was that a MOSFET is the simplest practical solution [#21680758][#21680760]
  • Charging resistor too low keeps SCR latched
    #1 21680754
    Graham Rounce
  • Use a pass transistor or pulsed DC to avoid SCR latching
    #2 21680755
    Rick Curl
  • #3 21680756
    Graham Rounce
  • Use a larger SCR or a MOSFET switch
    #4 21680757
    David Ashton
  • #5 21680758
    Rick Curl
  • 22 kΩ base resistor prevents capacitor charging
    #6 21680759
    Graham Rounce
  • PNP transistor changes to isolate SCR charging path
    #7 21680760
    David Ashton
  • #8 21680761
    Graham Rounce
  • Recommend Marston thyristor book and strong FET gate drive
    #9 21680762
    David Ashton
  • #10 21680763
    Graham Rounce
The discussion addresses the challenge of discharging a large electrolytic capacitor (10,000 µF) into a small coil using an SCR (Silicon Controlled Rectifier) as a switch without the SCR latching due to current from the charging path. The original circuit uses a resistor (R1) to limit charging current; however, lowering R1 to speed capacitor charging causes the SCR to remain latched because of holding current from the supply. The goal is to isolate the capacitor charging path from the SCR and coil discharge path without adding complex switching elements. Suggestions include using a small pass transistor to interrupt the charging supply during SCR conduction, employing low-voltage AC with a diode to create pulsed DC for capacitor charging, and adjusting gate-to-cathode resistor values to modify SCR holding current. Alternative solutions proposed are using a larger SCR with higher holding current or replacing the SCR with a transistor or MOSFET for better control and simpler switching. A more complex transistor arrangement was suggested to isolate the capacitor and SCR during discharge, but this increases circuit complexity. The consensus leans toward using a MOSFET switch due to its ruggedness and ease of control, especially given the large capacitor size and energy involved. Reference is made to R.M. Marston's "110 Thyristor Projects" as a useful resource for SCR applications. Proper trigger pulse amplitude and duration are emphasized for reliable switching, particularly with MOSFETs. The discussion also touches on practical considerations such as protecting FETs from damage during assembly and the importance of grounding.
