Breaker Didn’t Trip When Heater Wire Shorted to Ground on Blow Molding Machine—Why?
306 7
  • Why the breaker and fuses did not trip on ground fault
    #1 21682020
    Travis Rudloff
  • Clarifying cable, relay, and PLC damage details
    #2 21682021
    Rick Curl
  • #3 21682022
    Travis Rudloff
  • Clarifies 120 V PLC wiring and Crouzet relay setup
    #4 21682023
    Travis Rudloff
  • #5 21682024
    Rick Curl
  • #6 21682025
    Travis Rudloff
  • #7 21682026
    francis gyuhui
  • #8 21682027
    francis gyuhui
A blow molding machine's heater circuit includes 240V heating bulbs powered through fuses, a motor protector breaker/contactor, a PLC, and a relay. A 24-conductor cable supplies power to the heaters via a 24-pin plug. A short to ground on one wire caused the relay coil to catch fire and damaged four outputs on the PLC, but the motor protector breaker and fuses did not trip. The PLC operates at 120V on inputs and outputs, with the 240V supply split at the contactor: 120V feeds the PLC and relay coil, while 240V feeds the relay contacts and heaters. The relay involved is a Crouzet XTRIR3. The failure likely occurred on the relay coil side. The unusual wiring setup and voltage splitting may explain why the breaker did not trip during the short circuit.
