Why Did 3 Pole Breaker Trip but 90A Time Delay Fuses Didn’t Blow on 50HP Motor?
330 7
  • Phase-to-phase motor short likely caused breaker trip
    #1 21683279
    Christopher Moya
  • #2 21683280
    Elizabeth Simon
  • Overload and 90A fuses should have cleared first
    #3 21683281
    Christopher Moya
  • Fuse trip curves can lag faster breaker trips
    #4 21683282
    Elizabeth Simon
  • #5 21683283
    Christopher Moya
  • #6 21683284
    Elizabeth Simon
  • #7 21683285
    colin adam
  • #8 21683286
    FauxN Cotton
A 50HP, three-phase, 480VAC industrial compressor motor rated at 80A experiences immediate main breaker trips upon startup. The system includes a 175A three-pole circuit breaker and a disconnect switch with three 90A time delay fuses. Despite a detected phase-to-phase short in the motor, the 90A time delay fuses did not blow, and the motor overload protection did not trip, leading to the breaker tripping first. Time delay fuses can tolerate currents up to twice their rating for a duration, allowing a faster-acting breaker to trip before fuse operation. The fuse rating and type may be inappropriate for the motor's startup and fault conditions. Recommendations include reviewing trip curves for both fuses and breakers to understand coordination and consulting the motor/compressor manufacturer for proper fuse specifications. Fast-acting fuses are not necessarily suitable without knowing the motor's startup current and fault characteristics.
