Extending WINGONEER DC 5V Ultrasonic Sensor Cable 250ft for River Water Level Measurement
231 6
  • #1 21682596
    Bern Stalp
  • #2 21682597
    Rick Curl
  • #3 21682598
    Aubrey Kagan
  • #4 21682599
    Bern Stalp
  • #5 21682600
    Chip Fryer
  • #6 21682601
    Rick Curl
  • #7 21682602
    George Krasle
✨ The discussion addresses the feasibility of extending the cable length of a WINGONEER DC 5V Waterproof Ultrasonic Distance Sensor to 250 feet for river water level measurement. Due to the 40 kHz ultrasonic signal, it is recommended to keep the transducer close to the control module, ideally housed in a waterproof enclosure, as long cable runs can degrade signal integrity. Environmental factors such as temperature, humidity, and barometric pressure affect measurement accuracy, with temperature compensation being critical. The sensor's maximum effective range is approximately 4.5 to 10 feet, which may limit its application depending on river conditions. Alternative approaches include using a stilling well with a float sensor to mitigate water surface disturbances caused by wind, or employing a time-of-flight optical sensor from Broadcom capable of measuring distances up to 10 meters in daylight. For signal processing, local microcontroller units (e.g., PIC or Arduino) near the sensor are advised to handle measurements and transmit processed data over long distances via electrical, RF, or optical means. Another suggested method is a bubble gauge system that measures water level by air pressure through a tube, suitable for turbulent, debris-filled streams, though it requires higher power during measurement. Overall, extending the sensor cable directly to 250 feet is not recommended; instead, local processing or alternative sensing methods are preferred for stable and accurate river water level monitoring.
