Measuring Water Level in a Well: Non-Electric Continuous Measurement Tool for 110 cm Depth
mirekt357 6849 4
  • #1 16836187
    mirekt357
    Hello!
    I recently bought a plot with a cottage and a well. Recently, I have been tired of the high water level - about 110 cm below the ground level. I have basements so I'm afraid they might get flooded.
    I was looking for some simple instrument - non-electric for continuous measurement - so that I could approach the water level at any moment, without opening the hatch (sweeping leaves, needles, etc. - the well gets dirty).
    I didn't find anything like that so I came up with something like this Measuring Water Level in a Well: Non-Electric Continuous Measurement Tool for 110 cm Depth
    • Measuring Water Level in a Well: Non-Electric Continuous Measurement Tool for 110 cm Depth poziom wody w studni.jpg (60.71 KB) You must be logged in to download this attachment.
  • #2 16836385
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    And how does it work?
  • #3 16836442
    Plumpi
    Heating systems specialist
    Help: 874
    Rate: 2678
    The simplest solution is a float connected to a plastic pole. Pole led out through a piece of plastic pipe mounted in the cover of a concrete well.
    Multi-colored stripes can be painted on the pole, e.g. every 10cm. You don't even have to go to the well to read the water level.
  • #4 16836581
    mirekt357
    I thought about it too. Except that the pole would have to be about 4 m. At a high level, it would protrude over two meters above the hatch. I have tree branches above the hatch.
  • #5 16836604
    Qbuś
    Help: 380
    Rate: 876
    You can choose the pole so that it starts showing from the dangerous level, how the level will be lower, it will just hang in the well :) .
