Ultra Low Power Op-Amp for 12V Battery, Output to 0V, <100uA Supply Current?
291 9
How can I reduce the quiescent current of a 12V battery-powered relay driver that still needs to pull its output down to 0V?
You cannot get the circuit down to under 100uA just by choosing a different op-amp if the resistor network stays as shown, because the 10k resistor dominates the current draw [#21683142] A low-power candidate mentioned in the thread is the TLC2252CD, which is a rail-to-rail dual op-amp with 35uA supply current, 16V maximum supply voltage, and 50mA output current per channel [#21683137] To reduce total quiescent current, the resistor values need to be increased substantially so they no longer dominate the supply current [#21683142] That change can create bias-current, offset, and temperature-coefficient problems, so the op-amp and resistor values have to be chosen together [#21683142]
  • #1 21683133
    Graham Rounce
  • #2 21683134
    Elizabeth Simon
  • #3 21683135
    Chip Fryer
  • Quiescent current is 1 mA in relay circuit
    #4 21683136
    Graham Rounce
  • #5 21683137
    Konstantinos Ifantidis
  • #6 21683138
  • #7 21683139
    lea lovelea
  • #8 21683140
    Leslie Woods
  • TI low-power op-amp search recommendation
    #9 21683141
    Mark Wagner
  • 10 kΩ resistor dominates current draw
    #10 21683142
    Richard Gabric
The discussion centers on finding an ultra low power operational amplifier suitable for a 12V battery-powered circuit driving a 20mA relay, with a target supply current under 100µA. The original circuit uses an LM324 op-amp, which draws about 1mA quiescent current, considered too high for battery operation. Suggestions include searching component parameters on distributor sites like Digikey and Octopart for low quiescent current devices. One recommended alternative is the TLC2252CD, a rail-to-rail op-amp with a 35µA supply current and 16V maximum supply voltage, capable of delivering 50mA output current per channel. It is noted that resistor values in the circuit significantly affect current draw, and increasing resistor values to reduce current may introduce offset and temperature coefficient issues. Texas Instruments is highlighted as a leading manufacturer of low power analog devices, with some op-amps offering quiescent currents below 1µA. Overall, careful selection of both the op-amp and supporting passive components is necessary to achieve ultra low power operation.
