How Does Oil-Immersed Vehicle Pressure/Temperature Sensor Detect Fluid Temp Through Insulation?
252 6
  • Metal rod likely conducts heat to the temp sensor
    #1 21684319
    garth lemon
  • Glue slows response but can skew readings if rear cools
    #2 21684320
    Edward Chase
  • #3 21684321
    garth lemon
  • #4 21684322
    garth lemon
  • #5 21684323
    garth lemon
  • Microcontroller analog input recommended for sensor readings
    #6 21684324
    Muhammad Umar
  • Microcontroller analog pin recommended for sensor readings
    #7 21684325
    Technical Shahzad
A vehicle pressure/temperature sensor designed for oil immersion was examined to understand its temperature sensing mechanism despite insulation by a glue-like substance covering the PCB and temperature sensor. The pressure sensing is straightforward via a hole in the sensor body, but the temperature sensor, an analog thermistor embedded in insulating glue and bonded to a metal rod, raised questions about heat transfer. The metal rod likely conducts heat from the oil to the thermistor through the insulation. Testing showed minimal voltage change in response to temperature shifts, suggesting slow thermal response or insufficient signal amplitude. The sensor output is analog, arranged in a voltage divider circuit, requiring external amplification or microcontroller analog input for effective reading. Time delay is necessary for the sensor to stabilize and reflect temperature changes accurately. Overall, the insulation slows response but does not prevent temperature detection, and external circuitry is recommended to process the low-level analog signal.
