Safe Sequence for Switching Motor Direction in IRF4905/IRFZ44N H-Bridge with Arduino
552 6
  • Safe direction-change sequencing for H-bridge MOSFETs
    #1 21684392
    Brandon Stitt
  • #2 21684393
    Elizabeth Simon
  • #3 21684394
    Brandon Stitt
  • #4 21684395
    steve roberts
  • #5 21684396
    Brandon Stitt
  • Use BTN8960 half-bridge drivers for protection
    #6 21684397
    Chris Baron
  • Off-topic router support promotion
    #7 21684398
    edward kortiz
The discussion addresses the safe switching sequence for reversing motor direction in an H-bridge circuit using IRF4905 P-channel and IRFZ44N N-channel MOSFETs controlled by an Arduino with optocouplers. Clarification was made on terminology, where "open" and "closed" refer to valve-like states rather than MOSFET conduction states. The main concern is avoiding shoot-through by ensuring that complementary MOSFET pairs (Q1/Q3 and Q2/Q4) are never simultaneously conducting, which would short the power supply. Suggested switching sequences involve carefully timed transitions to prevent both pairs from being on at once. Additional recommendations include adding protective diodes across the MOSFETs to handle inductive voltage spikes, with discussion on whether the internal body diodes suffice or if external Schottky diodes are preferable. It was also advised to maintain at least one MOSFET on during switching to dissipate energy safely and avoid damaging voltage spikes. For improved reliability and integration, the use of dedicated half-bridge driver ICs such as the BTN8960 or BTN8962 was proposed, which include built-in drivers, protection, and current sensing, and are better suited for high current applications. The limitations of optocouplers for fast MOSFET gate driving were noted, emphasizing the need for fast gate transitions to reduce losses and stress on components.
