LC Filter for 2.69V 250Hz AC to Pure DC: Capacitor and Inductor Value Selection
294 9
How do I design an LC or pi filter to smooth a rectified 2.69 V, 250 Hz AC signal into pure DC when the output is still highly pulsating?
To get smoother DC, place a capacitor immediately after the rectifier/diode and then add the LC or pi filter after it, because the rectifier plus smoothing capacitor does the first stage of DC smoothing [#21684447][#21684449] If the ripple is still high, the issue may be the smoothing capacitor itself, so try a tantalum capacitor or parallel different capacitor types before the filter [#21684452]
  • #1 21684446
    Elliot Omoru
  • #2 21684447
    Elizabeth Simon
  • #3 21684448
    Elliot Omoru
  • #4 21684449
    Elizabeth Simon
  • #5 21684450
    Elliot Omoru
  • #6 21684451
    Andrs FEHR
  • #7 21684452
    Andrs FEHR
  • #8 21684453
    Elliot Omoru
  • Turn-on surge limits rectifier and capacitor sizing
    #9 21684454
    PeterTraneus Anderson
  • #10 21684455
    Grace GraceJordan
A designer working with a 2.69 V, 250 Hz AC source has successfully rectified the AC input to pulsating DC but struggles to achieve a pure DC output using an LC filter. The discussion clarifies that rectification requires a diode and capacitor stage before filtering. It is recommended to place a smoothing capacitor immediately after the diode rectifier to reduce ripple significantly, followed by an LC or pi filter if further smoothing is needed. High ripple levels suggest the need for improved capacitor quality; using tantalum capacitors or paralleling different capacitor types can enhance high-frequency smoothing performance. Additionally, considerations for inrush current and surge protection at turn-on are important for capacitor and rectifier longevity. Implementing these suggestions resulted in successful ripple reduction and a more stable DC output.
