Thesis ideas for electronic engineering: digital systems, Python, C++, Java, assembler
435 10
What thesis topics can I investigate in electronic engineering using my background in digital systems and programming?
You could base your thesis on a data acquisition or digital control system, or on security and encryption for radio-wave signal transmission [#21684713][#21684711] You can choose the complexity to match your thesis level [#21684713] One example is a system that maintains a water bath at a given temperature by measuring temperature and controlling a heater, and maybe a stirrer [#21684713] Other examples are feeding material into a container while monitoring weight and stopping at the correct weight, or monitoring temperature in multiple locations and analyzing the results [#21684713] For the security topic, the suggestion was to study sending signals with radio waves using RSA algorithms [#21684711]
  • #1 21684709
    Sebastian giraldo
  • #2 21684710
    dorcas melda
  • #3 21684711
    Giovanni Di Maria
  • #4 21684712
    Sebastian giraldo
  • Data acquisition and digital control thesis ideas
    #5 21684713
    Elizabeth Simon
  • #6 21684714
    Paul Anderson
  • #7 21684715
    Grace GraceJordan
  • #8 21684716
    Kolevi
  • #9 21684717
    idsbobet369
  • #10 21684718
    acelectric103
  • #11 21684719
    Tor90
A student of electronic engineering with skills in digital systems and programming languages including Python, C++, Java, and assembler seeks thesis topic ideas. Suggested areas for investigation include security and encryption systems using radio wave signal transmission combined with RSA algorithms. Practical project ideas involve designing data acquisition or digital control systems, such as temperature regulation for experimental water baths using sensors and actuators (heaters, stirrers), automated material feeding with weight monitoring, and multi-location parameter monitoring with data analysis. Emphasis is placed on adjusting project complexity to thesis level. Additional advice includes extensive reading of relevant technical articles and gaining practical experience.
