How to Verify 70 MHz Output From Unbranded VCO With Spectrum Analyzer and DIY Antenna
300 21
How can I tell whether my unbranded 70 MHz VCO is actually transmitting when my spectrum analyzer only shows a small change in the noise floor?
A small change in the noise floor does not prove the VCO is transmitting; if it is oscillating you should see a clear narrow peak at one frequency [#21684809] Make sure the spectrum analyzer has its own antenna, place it close to the VCO antenna, and use shielding such as aluminum foil if needed to reduce interference from nearby signals like a broadcast station [#21684809] [#21684816] If the control voltage is left undefined, the output frequency will also be undefined, so apply a known control voltage; one suggestion is to start around half the supply rail and use a potentiometer from ground to the rail [#21684812] [#21684825] A stable oscillator and analyzer should show the peak in the same place each time, so moving spikes usually mean the settings, sweep speed, bandwidth, or control-voltage range need checking [#21684825] Do not add a 30 dB amplifier just to search for the signal, because a claimed 10 dBm output into 50 ohms is already about 2 Vp-p and extra gain can clip the waveform or just raise the noise floor [#21684819] [#21684822]
  • DIY antenna test suggests VCO is radiating signal
    #1 21684805
    david lopez
  • #2 21684806
    Elizabeth Simon
  • Spectrum analyzer reading suggests possible transmission
    #3 21684807
    david lopez
    #4 21684808
    david lopez
  • Need an antenna and proper analyzer settings
    #5 21684809
    Elizabeth Simon
  • #6 21684810
    david lopez
  • #7 21684811
    david lopez
  • #8 21684812
    Elizabeth Simon
  • #9 21684813
    david lopez
  • #10 21684814
    Elizabeth Simon
  • #11 21684815
    david lopez
  • Shielded near-field coupling test with foil
    #12 21684816
    Elizabeth Simon
  • #13 21684817
    david lopez
  • #14 21684818
    david lopez
  • 10 dBm into 50 ohms needs no amplifier
    #15 21684819
    Richard Gabric
  • #16 21684820
    david lopez
  • #17 21684821
    david lopez
  • Overdrive causes clipping and harmonic distortion
    #18 21684822
    Richard Gabric
  • #19 21684823
    david lopez
  • #20 21684824
    david lopez
  • Check analyzer settings and VCO control voltage
    #21 21684825
    Richard Gabric
  • #22 21684826
    david lopez
A user purchased an unbranded voltage controlled oscillator (VCO) from a Chinese seller claiming a 70 MHz output at 0 V control voltage and 10 dBm output power. The user connected the VCO to a coaxial cable stripped to act as a DIY antenna and attempted to detect the signal using a spectrum analyzer. The spectrum analyzer showed peaks around -25 to -30 dB, but the user was uncertain if these represented the VCO output or noise. The user confirmed the spectrum analyzer's functionality by detecting a local broadcast at 100 MHz. It was advised that the VCO requires a defined control voltage to produce a stable frequency output; leaving control voltage pins floating results in an undefined frequency. Suggestions included placing the VCO antenna close to the spectrum analyzer antenna and shielding both to reduce interference from local radio stations. The user lacks an oscilloscope, complicating direct waveform verification. Amplification of the signal was considered but cautioned against due to potential severe clipping, waveform distortion, and increased harmonic content if the VCO output is already at 10 dBm (2 V peak-to-peak in a 50 Ω system). Proper spectrum analyzer settings (sweep speed, bandwidth) and controlled variation of the control voltage, ideally via a potentiometer from 0 V to supply voltage, were recommended to observe stable frequency peaks and verify VCO operation.
TL;DR: A 10 dBm VCO should produce about 2 Vp‑p into 50 Ω; avoid over‑amplifying because “any further amplification…causes severe clipping.” [Elektroda, Anonymous, post #21684819]
Why it matters:** This FAQ helps budget‑limited builders verify a ~70 MHz VCO with a spectrum analyzer and DIY antennas, without a datasheet or oscilloscope.
How do I verify my unbranded VCO around 70 MHz on a spectrum analyzer?
Attach a simple antenna to the analyzer, place it near your VCO’s coax “antenna,” and scan around the expected frequency. First confirm the analyzer sees a known local station, then look for a distinct narrow peak from your VCO. Keep the antennas close for better coupling. [Elektroda, Anonymous, post #21684809]
Why did my noise floor drop from about −25 dB to −30 dB when I power the VCO?
That change alone does not prove transmission. A working VCO appears as a clear, narrow peak at a specific frequency. Ensure the analyzer has an antenna and proper span, then check near 70 MHz while the VCO is powered. [Elektroda, Anonymous, post #21684809]
What happens if the control voltage pin is left floating?
A floating control voltage makes the output frequency undefined. Apply a known control voltage to set the frequency, then observe the analyzer for a stable peak. [Elektroda, Anonymous, post #21684812]
How should I apply control voltage without a datasheet?
Use a potentiometer to sweep the control pin from ground to the VCO supply, starting near mid‑supply. This keeps tuning within a reasonable range and avoids unstable regions. “Start at a middle setting.” [Elektroda, Anonymous, post #21684825]
Can a 30 dB RF amplifier help me see the signal?
If your VCO truly outputs 10 dBm, adding high gain often drives amplifiers into clipping and increases harmonics. If the VCO isn’t oscillating, an amplifier only raises the noise. Verify oscillation before adding gain. [Elektroda, Anonymous, post #21684819]
What exactly is clipping here?
Clipping is when an overdriven amplifier forces the waveform to the supply rails, turning a sine into a squarer wave and polluting the spectrum. “As you approach a square wave the odd harmonics increase.” [Elektroda, Anonymous, post #21684822]
I see spikes that move when I connect ~4 V to the control pin—does that prove RF output?
Not yet. A stable oscillator and analyzer should show peaks in the same place. Set sensible sweep speed/RBW and tune the control voltage slowly within range. If peaks drift, your settings or control range may be off. [Elektroda, Anonymous, post #21684825]
How do I keep strong broadcast stations from masking my VCO?
Place the VCO and analyzer antennas very close, then add a grounded aluminum‑foil shield around both to block outside signals. Avoid shorting your circuit to the foil. [Elektroda, Anonymous, post #21684816]
How can I sanity‑check my analyzer setup quickly?
Tune the analyzer to a known FM broadcast around 100 MHz and verify a strong peak. This validates your antenna and analyzer chain before chasing your VCO. [Elektroda, Anonymous, post #21684810]
What antenna should I use at the analyzer input?
Use a small improvised antenna similar to your VCO’s radiator (e.g., short coax stub). Proximity coupling at tens of centimeters or less works for bench tests. [Elektroda, Anonymous, post #21684809]
What does 10 dBm mean in volts for a 50 Ω system?
10 dBm is commonly stated for 50 Ω loads and corresponds to about 2 Vp‑p at the output in this discussion. Treat it as a strong bench‑level signal. [Elektroda, Anonymous, post #21684819]
I don’t own an oscilloscope—what’s a simple three‑step method to verify output?
  1. Put a short antenna on the analyzer and another on the VCO, tips a few centimeters apart.
  2. Wrap both with grounded foil to reject outside stations.
  3. Sweep the analyzer near 70–110 MHz while adjusting the control voltage slowly. [Elektroda, Anonymous, post #21684816]
What is a VCO in plain terms?
A Voltage‑Controlled Oscillator generates RF whose frequency changes with an applied control voltage; leave it floating and the frequency wanders. [Elektroda, Anonymous, post #21684812]
Which analyzer settings matter most so I don’t miss the carrier?
Use a narrow resolution bandwidth and appropriate sweep speed. If RBW is too wide or sweeps are too fast, a narrow carrier can vanish in the display. [Elektroda, Anonymous, post #21684825]
