Firmware Request for Lifemaxx LF-32HD470R SMART, Vestel 17MB211S, VE8315WNDB-2D-N21
zabadioui2003 681 3
  • #1 21807162
    zabadioui2003
    Hello, elektroda!
    I need software for TV Lifemaxx LF-32HD470R SMART, motherboard Vestel 17MB211S and matrix code VE8315WNDB-2D-N21. Any working version will do. The TV is stuck in boot loop after bad software update - it turns black with LED flashing red and then repeats. No reaction to any input from remote/button on the TV.
    Thank you very much!
  • #2 21807237
    yokoono51
    Help: 172
    Rate: 316
    You have a compatible software here. Same main and same panel. If the OK key on the remote control is not active you cannot install the software. After installation you may need a Finlux remote control. Try at your own risk.
    https://files.fm/u/ujz8cm63z
  • #3 21807554
    zabadioui2003
    >>21807237 any way to force-install it without the remote?
  • #4 21807566
    yokoono51
    Help: 172
    Rate: 316
    1. I don't know. Buy a programmer and rewrite the flash memory with the dump for this TV.
    2. Look for a programmable remote control and maybe you'll find the code on the TV
    3. Check which TV model the software was rewritten from and buy the remote control.
