Seeking Rotel FAX-88A Bookshelf Receiver Service Manual with Alignment Instructions
ns8s 453 0
  • FM alignment needed for stereo lamp and right channel
    #1 21837006
    ns8s
    I am looking for the Rotel FAX-88A bookshelf receiver service manual (with adjustments) wanted. I have a good schematic, just need service alignment information. Anyone? Thanks!
    AI: Are you looking for alignment instructions for a specific section of the FAX-88A (like the FM tuner, AM tuner, or audio section), or do you need the full alignment procedure?
    Full alignment procedure
    AI: Is there a particular issue or symptom with your receiver that you're trying to address with the alignment instructions?
    No stereo indicator lamp, and low level right channel when only using FM. AM and other inputs, balance is perfect.
