W211 rear suspension not lifting after new sensor and compressor replacement
lukryb54 906 2
  • #1 21843463
    lukryb54
    Hello, I have a problem with my W211. The rear suspension sensor has been replaced and after replacement it will not lift. The compressor has been replaced with a new one, fuses, relays new and it does not lift, what could it be, help
    Moderated By CameR:
    Separated from archived topic:
    https://www.elektroda.pl/rtvforum/topic3392717.html#16793277
    Reg. 3.1.19 Publishing posts in archived discussions.
  • #2 21843762
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    lukryb54 wrote:
    what could be
    Have you read the car errors ?
    Have you looked at the running parameters ?
    The repair is carried out in a heated garage or in sub-zero temperatures (freezing water) ?
    The compressor works but does not lift or does not start the compressor ?
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 21844036
    lukryb54
    The compressor worked for a while and then stopped, i.e. 2 seconds. The error was 5345, 5506. such errors came out
