[Solved] Delphi B420 Low SS Radio Code Extraction from 24LC32 EEPROM Dump (Ford Ka/Fiat 500)
Don_Ughetto 1143 5
  • Repeated EEPROM block likely not the radio code
    #1 21863515
    Don_Ughetto
    Hello everyone,
    I’m trying to recover the radio code from a **Delphi B420 Low S&S** unit removed from a **Ford Ka (2009–2012 platform, shared with Fiat 500)**.
    The radio requested the code after a battery disconnect, and unfortunately the original code card is missing.
    I decided to read the EEPROM directly to try to recover the code.
    Radio information
    Model:
    Delphi **B420 Low S&S**
    Part numbers found on the unit:
    Prod Date : 1312
    Serial Number : 7355597070
    HW Ver : 28346965
    28316510
    EEPROM type:
    24LC32 (I²C)
    Tools used
    Programmer: CH341A USB programmer
    Software used to read EEPROM:
    NeoProgrammer
    Connection method:
    SOIC8 clip directly on the EEPROM (in circuit)
    The radio was completely disconnected from the vehicle during the reading.
    Dumps obtained
    Dump1–first read original B420 unit selled with car Dump1.bin (4 kB)You must be logged in to download this attachment.
    Dump2 – second read (identical to Dump1, confirming good contact) Dump2.bin (4 kB)You must be logged in to download this attachment.
    Dump3 – dump from a second identical B420 unit, buyed to compare if the first one have any problem. Dump3.bin (4 kB)You must be logged in to download this attachment.
    All dumps are **4096 bytes** (24LC32).
    The first two dumps are identical, so the read should be correct.
    I noticed a repeated block around address
    0x0B30
    in the dumps:
    80 02 32 14 64 00 14 19 6F 03 E2 1E 40 1F 32 06
    00 80 02 32 14 64 00 14 19 6F 03 E2 1E 40 1F 32
    ASCII view looks like:
    ..2.d...o...@.2.
    This block is identical between different radios, so it probably isn't the code itself.
    Large differences between dumps appear mostly in areas containing **RDS station names**, so those are probably user presets.
    I would like help with one of the following:
    1. Extracting the **radio code directly from the EEPROM dump**, or
    2. Identifying the **offset/algorithm used by Delphi B420 Low units**, or
    3. Confirming if the code is **calculated from an internal identifier rather than stored directly**.
    If needed I can also provide:
    * full EEPROM hex view
    * pictures of the radio PCB
    * EEPROM location
    Thanks in advance for any help or guidance.
    AI: Can you share the serial number from the radio’s label (not just the part numbers), as some code algorithms require it or use it as a basis for calculation?
    7355597070283469651209001020
    JayRo
    Help: 718
    Rate: 968
    Dump1, dump2 - 3614, dump3 - 5451.
  • #3 21863632
    Don_Ughetto
    >>21863583 Hello JayRo,
    I'll try tonight and I'll tell you the result. Thank you for the quick answer.
    Have a nice day!
    JayRo
    Help: 718
    Rate: 968
    By the way, the code is located in offset #10-#11 (EA A7) encrypted by Grundig algorithm. Good luck!
  • #5 21864332
    Don_Ughetto
    Thank you so much, JayRo,
    It works!
    I solved the topic.
    Have a nice day.
  • #6 21864336
    Don_Ughetto
    The code that JayRo gave me, and entered has unlocked my radio.
