The discussion addresses extracting or calculating the radio code for a Fiat Doblo car radio using a 24LC32 EEPROM dump. Initial identification suggested the radio might be a Blaupunkt 764 633 1316, but memory reading was deemed incorrect. Further analysis confirmed the radio is a Grundig model, with coding similar to Delphi radios, specifically Delphi 7355657250. The suggested code "1512" was proposed multiple times but did not unlock the radio. It was noted that if the radio displays "CODE ERROR," it must be connected to the car's CAN bus for the code to be accepted. Ultimately, the original code extraction was unsuccessful, and the user considered replacing the car stereo. AI summary based on the discussion. May contain errors.
