Samsung UE55MU6479 No Standby Light—Which Memory Chip to Flash and Firmware Needed?
anderle98 270 2
  • #1 21867585
    anderle98
    Hi, my Samsung UE55MU6479 stopped working. No standby light; when I disconnect the PSU cable to the mainboard, the backlight turns on. In this forum, other people had the same problem with similar TVs and flashed some memory chip to fix it. Can somebody please point me in the right direction as to which chip to flash and what firmware to use? Thanks a lot!
  • #2 21867782
    zdzich42
    Help: 586
    Rate: 863
    You have a working power supply and backlight. The motherboard is faulty. Do you have diagnostic capabilities? I have no knowledge if a soft exists and if it will help in case even the standby led does not light up.
