[Solved] Samsung UE55F9000 - black screen, no backlight, unable to start, LED
Qwai 5670 5
  • Backlight absent with white standby light
    #1 17010675
    Qwai
    Hi
    I have a problem with the UE55F9000 TV.
    As my wife says (because I was not at home then), my two-year-old son got the remote, clicked something on the menu and the TV turned black. I don't believe it a bit, but I swear that it was so, and the TV is hanging on the wall, so my son has no chance to reach him.
    Currently, the TV only has a white light after turning on the power, as if it was turned on and when pressing the buttons on the remote control, the red LED flashes, besides, the screen is completely black, even the backlight does not work.
    After disconnecting the smart box, the TV turns on and off with the remote control (the white light goes out), the rest of the symptoms are identical.
    Main board BN-01950C
    Logic BN-02076
    tcon VD_556EU22BC6LV0.1
    PDU L65D2L_DSM BN-00675A
    Any suggestions are welcome.
    best regards
  • #2 17010797
    majsterek
    Help: 79
    Rate: 70
    Can you enter "service mode" ?.
    If so, perform a factory reset.
  • #3 17010844
    Qwai
    The TV does not display anything even the logo: - /
    The backlight does not turn on and when I put the flashlight on, the matrix is dead.
    The only idea I have is to replace the motherboard with another used one.
  • #4 17049528
    Qwai
    Motherboard and power supply replaced, but unfortunately no effect.
    What should the TV display without one connect connected?
  • #5 17055147
    Qwai
    For posterity, the disc with the matrix logic was a problem.
    Everything works after replacement
  • #6 17055149
    Qwai
    Added after 33 [seconds]:
    Exchange of matrix logic
