Nevir 28" TP.S506.PB818 D28f2000 screen flipped dump request
nanomicrome 507 1
  • Original dump added; need panel sticker details
    #1 21898732
    nanomicrome
    Can someone help fix a Nevir 28" NVR-7406-NVR28HD-N with tp.s506.pb818 screen marking d28f2000, its a mt3151a05-5-xc5 tcon with the st2751a marking, it was in boot loop, i tried several dumps but the screen is always flipped, tried manual mirror of the mt315 tcon but it didn't work. I will add the copy of the "bad Dump" to the post.
    cheers
    Can you post the full panel sticker/model from the LCD (all numbers/letters), and confirm if the panel + mainboard are the original ones from this TV?
    yes its the original
    Do you still have the original backup dump from this set, and with the original dump was the image also flipped or did this start only after flashing other dumps?
    the original dump is added but its on boot loop
    • nevir d28-f2000.bin (4 MB) You must be logged in to download this attachment.
