Kunft 28DCG220014 TP.SIS231.P83 boot loop, SPI flash dump/firmware?
joels1989 564 5
  • Requesting panel and SPI flash part numbers
    #1 21892374
    joels1989
    I have a Kunft LED TV model 28DCG220014 (serial G919A4DF2EA163581) with the following issue: when I power it on, the logo appears, but after a few seconds it shuts down and restarts, getting stuck in a continuous boot loop.
    I have searched several forums and found reports from other users with the same problem, where it is suggested that it may be related to SPI flash memory corruption.
    However, I have not been able to find compatible firmware or clear instructions on how to reflash this TV.
    I would like to know:
    * If anyone has a dump/firmware for this model (or for mainboard TP.SIS231.P83 or equivalent)
    * If it is possible to update via USB or only through an SPI programmer
    * If anyone has already solved this issue and can share the procedure
    Additionally, I would like to know if there are compatible mainboards available for purchase (new or used), and where I could find them.
    AI: Could you share the exact LCD panel model (from the sticker on the panel) and any full code/revision printed on the mainboard, not just “TP.SIS231.P83”?
    28DCG220014
    AI: Have you already tried any recovery method (USB update, factory/service menu, or reading/writing the SPI chip), and if so, what is the exact SPI flash chip part number?
    TP.SIS231.P83
  • USB recovery procedure and SPI flash replacement
    #2 21892392
    billobirillo
    Help: 338
    Rate: 797
    according to serial number
    model KUNFT 28DCG220014, main TP.SIS231.P83, panel M280X13-E3-H(G3)
    here is the firmware
    how to perform a usb recovery
    copy the file SISEU23X8M.bin on an empty usb stick fat32 formatted
    unplug the power cord
    insert the usb stick in the tv and reconnect the power cord
    look at the standby led, at the beginning it flashes slowly, after about 1 minute it doubles the speed, update completed
    unplug the power cord and the usb stick
    reconnect the power cord and turn on the tv: it will start in first installation mode
    if it doesn't work with the usb recovery, you have to replace the spiflash U5 25Q64 and program a new one using the file SISEU23X8M.bin
    • CH_LSER_PT_V20.0238.rar (5.33 MB) You must be logged in to download this attachment.
  • #3 21893459
    jeloi
    Help: 285
    Rate: 597
    Publish defective bin.I can repair.
  • USB recovery failed; requesting SPI flash reprogramming guidance
    #4 21894006
    joels1989
    Thank you very much for your help and for providing the firmware.
    I tried the USB recovery procedure exactly as described (FAT32 USB stick, correct file name, power cycle, etc.), but unfortunately it did not work. The TV still remains stuck in the boot loop.
    I would like to proceed with the SPI flash replacement/reprogramming (U5 – 25Q64) using the file SISEU23X8M.bin.
    Do you happen to have any detailed instructions, tutorial, or guidance on how to properly replace and program the SPI flash for this board? Any recommendations regarding tools, procedure, or precautions would be greatly appreciated.
    Thank you again for your support.
    Best regards,
  • #5 21896664
    joels1989
    @billobirillo can you please help me regarding my last message in the forum?
  • #6 21896712
    billobirillo
    Help: 338
    Rate: 797
    @joels1989 I sent you a private message: check it
