[Solved] Where to download firmware for Electronia LD2 32Android Vestel 17MB171 VES315WNGB-2D-N52?
TugaGeek 498 3
  • Stuck on memory almost full message
    #1 21926240
    TugaGeek
    Hello. I need your help, please.
    I need the firmware for a TV Electronia LD2 32Android, with the hardware Vestel 17MB171 and VES315WNGB-2D-N52.
    Thanks for all the attention and help that you can give.
    Can you please share the exact model number, serial number, and product/code number from the sticker on the back of the TV?
    What is the problem with the TV now, and can you still access the menu to see the current software/firmware version?
    System fails to work, it is stuck on memory almost full message.
    billobirillo
    Help: 338
    Rate: 801
    main 17MB171, panel VES315WNGB-2D-N52, cell BOE HV320WHB-F55
    software link
    link valid for 7 days
    the software is from a Telefunken, but it fits perfectly on your Electronia
    if there are problems on the image, specify the panel driver, so I can send you the correct sw
  • #3 21927183
    TugaGeek
    >>21926559
    My friend, it worked like a charm.
    Thank You for everything and i wish you good fortune and health to you and to your family as well.
  • #4 21927752
    TugaGeek
    Just follow the procedures with the software the user billobirillo gave and it went 100%.
