You're viewing a topic that has been removed.
TH03 Pro Temperature Humidity Sensor Compatibility with OpenBeken Integration (possibly)
divadiow 57 0
  • TuyaMCU v3 low-power mode added
    #1 21935110
    Help: 442
    Rate: 906
    I've updated TuyaMCU test driver a little.
    Behaviour/use is as follows
    startDriver TuyaMCU
    -> legacy normal TuyaMCU mode, unchanged.
    startDriver TuyaMCU; startDriver tmSensor
    -> legacy tmSensor/v0 battery-sensor mode, unchanged.
    startDriver TuyaMCU; tuyaMcu_v3LowPowerMode
    -> v3 low-power TuyaMCU mode.
    startDriver TuyaMCU; tuyaMcu_batteryPoweredMode
    -> compatibility alias for v3 low-power mode. (see thread)
    startDriver TuyaMCU; startDriver tmSensor; tuyaMcu_batteryPoweredMode
    or
    startDriver TuyaMCU; startDriver tmSensor; tuyaMcu_v3LowPowerMode
    -> tmSensor still wins while tmSensor is running.
    Skasowano z tematu: TH03 Pro Temperature Humidity Sensor Compatibility with OpenBeken Integration (possibly)
    przez divadiow dnia 08 Jul 2026 22:14
