How to enable 144Hz on Windows 11 with AOC 24G2 and RTX 3060 stuck at 60Hz?
techycorner247 393 3
  • Check monitor OSD and Windows advanced display settings
    #1 21944259
    techycorner247
    Hi everyone,
    I'm using a 144Hz monitor with a Windows 11 PC, but I can only select 60Hz in the display settings.
    Here's what I've already checked:
    - Installed the latest GPU drivers.
    - Tried different HDMI and DisplayPort cables.
    - Updated the monitor drivers.
    - Confirmed the monitor itself supports 144Hz.
    While troubleshooting, I also came across this Windows setup guide for the Yuzu emulator, which includes some useful checks for GPU drivers and Windows dependencies that may also help diagnose graphics-related issues: https://playwithyuzu.com/install-yuzu-windows/
    Could this be caused by the cable version, GPU limitations, or a Windows setting that I'm missing? What else should I check to enable the full refresh rate?
    Thanks in advance for any advice.
    AI: What are the exact models of your monitor and GPU, and is this a desktop PC or laptop?
    Monitor: AOC 24G2 (144Hz), GPU: NVIDIA GeForce RTX 3060, Desktop PC.
    AI: What cable/port are you currently using exactly — HDMI or DisplayPort, connected directly to the GPU or through an adapter/dock — and at what resolution are you trying to enable 144Hz?
    Connected directly to the GPU using a DisplayPort cable, running at 1920×1080 (1080p) while trying to enable 144Hz.
  • #2 21944570
    lisek
    Service technician RTV
    Help: 6354
    Rate: 6885
    Read Link
    the AOC 24G2 FreeSync the range is 48–144 Hz, and it works with compatible NVIDIA GPUs without issues as it is officially certified as ‘G-SYNC Compatible.’
    * FreeSync technology ... paired with AMD Radeon graphics,
    p.s
    Link_ best-1440p-monitor-for-rtx-3060
  • Possible DisplayPort cable or monitor setting issue
    #3 21945531
    techycorner247
    >>21944570
    Thanks for the clarification. It's good to know that the AOC 24G2 is officially G-SYNC Compatible with NVIDIA GPUs, so compatibility shouldn't be the issue. Since I'm still limited to 60 Hz over DisplayPort at 1920×1080, I'm trying to figure out what else could be preventing Windows from detecting 144 Hz. Could this point to a DisplayPort cable issue, monitor OSD setting, or something in the NVIDIA Control Panel?
  • #4 21946162
    lisek
    Help: 6354
    Rate: 6885
    Officially… ‘compatible with NVIDIA’ does not mean it supports 144Hz; it may support lower refresh rates, e.g. 120 or 90 Hz
    * It’s all nonsense and marketing
    Officially, AOC states
    Refresh Rate 144Hz (Adaptive, AMD FreeSync Premium)
    That said, the display supports Low Framerate Compensation (LFC) with a tested range of 48–144 Hz.
    1x DisplayPort 1.4, 2x HDMI 2.0
