Which WiFi module to choose for IoT: BLE, 2.4/5GHz, Mesh and low power?
chartloo 291 0
  • Overview of WiFi IoT module architectures and modes
    #1 21949905
    chartloo
    WiFi Technology White Paper for IoT Applications
    1. Executive Summary
    With the rapid development of the Internet of Things (IoT), WiFi, as one of the most ubiquitous wireless connection technologies, has become the core infrastructure for smart devices to connect to the network. This white paper aims to systematically elaborate on the core architecture, product system, application scenarios, and selection strategies of WiFi technology, providing industry customers with a comprehensive and professional reference for wireless WiFi solutions.
    2. Technical Architecture and Core Features
    2.1 Serial-to-WiFi Passthrough Technology
    Serial-to-WiFi passthrough modules encapsulate the complex WiFi protocol stack within the module. Users only need to send AT commands via a standard UART serial port for configuration, and the module automatically handles WiFi network connection, data encapsulation, and forwarding. This "plug-and-play" design philosophy significantly lowers the barrier for embedding systems to access WiFi networks.
    2.2 Multiple Operating Modes
    WiFi modules support three core operating modes:
    AP Mode (Access Point): The module acts as a hotspot, allowing other WiFi devices to connect directly. Suitable for local device configuration.
    STA Mode (Station): The module acts as a client, connecting to an existing WiFi router. Suitable for devices needing internet access.
    STA+AP Mode: Operates as both AP and STA simultaneously, enabling data bridging and network extension. Widely used in repeaters and gateways.
    2.3 Dual-Mode and Dual-Band Technology
    Dual-Mode WiFi (WiFi+BLE): Many modules integrate both WiFi and Bluetooth Low Energy (BLE). BLE serves fast provisioning and low-power broadcasting, while WiFi provides a high-bandwidth data channel.
    Dual-Band WiFi (2.4G+5G): The 5GHz band offers less interference and higher speeds, ideal for HD video transmission and industrial real-time control.
    2.4 Low-Power Technology
    Multi-level power optimization has been implemented across different WiFi series:
    Dialog DA16200-based series: Power consumption as low as microamp level while maintaining WiFi connection, supporting years of battery life.
    CC3200-based series: Supports four configurable power modes, minimum standby power consumption less than 5uA.
    WiFi6 series: Supports low-power mode with simultaneous STA and BLE slave operation.
    2.5 Distributed Mesh Network Technology
    The WiFi Mesh networking protocol (ESP-MESH) allows a large number of devices distributed over a wide area to connect to each other within the same WLAN, featuring self-organizing and self-healing properties. The network supports up to 1000 nodes and both router-assisted and routerless networking modes, suitable for smart buildings, farms, and campuses.
    2.6 Router-Level Gateway Technology
    Based on the MediaTek MT7688AN/MT7628AN chip, some modules support the OpenWrt operating system, allowing deep secondary development. These modules integrate Ethernet ports, USB, and SDIO, and can serve as core devices such as home routers, industrial gateways, and edge computing nodes.
    3. Product System and Functional Details
    3.1 Serial-to-WiFi Passthrough Module Series
    Model Chip Solution WiFi Protocol Tx Power Range Core Advantage
    E103-W01 ESP8266EX 802.11b/g/n 20dBm 100m Extremely cost-effective, mature ecosystem
    E103-W02 CC3200 802.11b/g/n 20dBm 100m Industrial-grade, 5uA ultra-low standby
    E103-W03 CC3220R 802.11b/g/n 20dBm 180m Industrial-grade + Ultra-low power
    E103-W10 ESP8285N08 802.11b/g/n 20dBm 250m Cost-effective, long range
    E103-W11 Proprietary SoC 802.11b/g/n/ax 20dBm 300m WiFi6+BLE5.1, supports OTA
    E103-W12C DA16200 802.11b/g/n 20dBm 500m Ultra-low power, stays connected
    E103-W13 CC3301 802.11a/b/g/n/ax 21dBm 500m WiFi6+BLE5.4, Industrial-grade
    3.2 Dual-Mode WiFi Module Series (WiFi+BLE)
    Model Chip Solution WiFi Protocol BLE Protocol Range Core Advantage
    E101-32WN4-PS ESP32-D0WD-V3 802.11b/g/n BLE4.2 400m Mature and stable, rich ecosystem
    E101-C3MN4-PS ESP32-C3 802.11b/g/n BLE5.0 200m RISC-V architecture, low power
    E101-C6MN4-PS ESP32-C6 802.11b/g/n/ax BLE5.3 300m WiFi6+BLE5.3
    EWM103-W15SX Proprietary SoC 802.11b/g/n BLE5.1 440m Low power + Dual mode
    3.3 Dual-Band / High-Performance WiFi Module Series
    Model Chip Solution Frequency Band Max Data Rate Interface Core Advantage
    E103-W06 CC3235S 2.4G+5G - UART Dual-band + Industrial grade
    E103-RTL8811CU RTL8811CU-CG 2.4G+5.8G 433Mbps USB2.0 Dual-band + Cost-effective
    E103-RTL8812CU RTL8812CU-CG 2.4G+5.8G 867Mbps USB2.0 Dual-band + High speed
    3.4 Router/Gateway-Level WiFi Module Series
    Model Chip Solution Frequency Band Main Interfaces Core Advantage
    E103-W20 (7688) MT7688AN 2.4G Ethernet + USB2.0 Supports OpenWrt, secondary development
    4. Application Scenarios and Selection Solutions
    4.1 Smart Home and Appliances
    Recommended Solution: E103-W01, E103-W10
    The module acts as an STA, connecting to a home WiFi router and communicating with a cloud server or mobile app. Enables remote control, status query, and scene linkage for smart sockets, lights, curtains, and air conditioners.
    4.2 Industrial Control and Data Acquisition
    Recommended Solution: E103-W02, E103-W03, E103-W06
    Modules support Alibaba Cloud, Baidu Cloud, OneNet, and standard MQTT protocols. Support Modbus protocol conversion (RTU to TCP) and can integrate with PLCs, HMIs, and sensors.
    4.3 Video and Audio Transmission
    Recommended Solution: E103-RTL8812CU, E103-RTL8811CU
    Dual-band WiFi with max 867Mbps data rate enables low-latency HD video transmission. Suitable for wireless cameras, drone FPV, wireless speakers, and video surveillance.
    4.4 Large-Scale Distributed Networks
    Recommended Solution: WiFi Mesh modules
    Supports up to 1000 nodes for self-organizing and self-healing networks. Ideal for smart buildings, farms, campuses, and hotels requiring large-area coverage.
    4.5 Routers and Edge Computing Gateways
    Recommended Solution: E103-W20 Series (OpenWrt)
    Serves as core router or edge computing node for local data preprocessing and protocol conversion. Suitable for industrial IoT and smart cities.
    4.6 Ultra-Low Power Battery-Powered Devices
    Recommended Solution: DA16200-based series
    Power consumption at microamp level while maintaining WiFi connection, enabling years of battery life. Ideal for smart locks, temperature/humidity sensors, asset trackers, and wearables.
    Tags: WiFi module, IoT, wireless communication, serial to WiFi, WiFi+BLE, dual-band WiFi, WiFi6, low power WiFi, WiFi Mesh, OpenWrt, Espressif, Texas Instruments, Realtek, MediaTek, Dialog, industrial IoT, smart home, industrial control, edge computing, technology white paper
