Netia Światłowód: własny router OpenWRT, VPN i publiczny adres IP – możliwości
maf2 684 2
  • #1 21846765
    maf2
    Rate: 9
    Mam pytanie o Netię Światłowód.
    Dwie sprawy. Czy można u nich bez problemu podpiąć własny router. Bo mam własny OpenWRT i VPN.
    Druga sprawa czy dają publiczny adres ip żeby można było otwierać porty itp itd.
  • #2 21846885
    DJ_KLIMA
    Help: 67
    Rate: 222
    You buy a permanent publisher for +10zl per month, you make a router from them in "bridge" mode and with your own equipment you set up PPP, since 2 years they ban unauthorised gpon inserts / modems, so the only option left is as I wrote, having an external permanent IP you also free yourself from CGNAT.
  • #3 21846912
    KOCUREK1970
    Help: 3861
    Rate: 5489
    maf2 wrote:
    Can you hook up your own router with them without any problems.
    You can.
    maf2 wrote:
    The second issue is whether they give you a public ip address so you can open ports etc etc.
    They don't, you have to pay 10 zł/month for it.
    The address is public, permanent.
