Yaesu FT-8900R - Need EEPROM dump file for 24C128 (S/N 1C3000266)
Lauro2026 54 0
  • Working FT-8900R 24C128 EEPROM dump requested
    #1 21952088
    Lauro2026
    Mark: Yaesu
    Model: Yaesu FT8900R
    Chassis (main board, components): Main Unit (uses 24C128 EEPROM)
    LCD Screen/Panel (if exists):
    More information: Hello everyone, I am working on a Yaesu FT-8900R (European version, Serial Number: 1C3000266) that is currently locked and not booting. Upon initial power-on, the radio draws about 90-100 mA for 1 second and then drops back to zero. Crucially, this behavior ONLY happens when my original EEPROM chip is installed. When the EEPROM is removed from the board, this initial current draw does not occur. This proves that the hardware is healthy and the I2C bus lines (SCL/SDA) are actively communicating between the CPU and the EEPROM, but the CPU shuts down because the data inside the memory file is corrupted. The original stock chip is a 24C128 (16 KB), but I am performing the repair using a new 24C256 (32 KB) chip. Please note: While I provided my serial number for reference, ANY working EEPROM dump (.bin or .hex file) from any other functioning Yaesu FT-8900R will be absolutely perfect! I just need to study the original factory structure, look at the hex rows, and see how the bits are organized. Once I have a reference file, I will manually compare it with my data, hex row by hex row, to reconstruct my boot sectors and CHIRP calibration blocks. If anyone has any backup file from a working 24C128, please share it. It will be an immense help. Thank you very much in advance for your assistance! Best regards, Lauro (IU0SQJ).
