Where to download JVC LT50CF890(C) firmware for 17MB170 and VES500QNDP-20-N43
trevorholt1963 186 10
How can I find compatible firmware for a JVC LT-50CF890(C) TV with a Vestel 17MB170 mainboard and VES500QNDP panel when the TV does not boot?
Try the firmware file shared at https://files.fm/u/6mavmsejgv9r2by9, but use it at your own risk because the thread does not confirm that it is a matching .bin file for this JVC model [#21956314] Search Elektrotanya for Vestel-related files and service documentation [#21956133] Also search for “VES500QNDP-2D-N43” or “VES500” and Finlux TV software/service manuals, since the panel was identified in the replies as VES500QNDP-2D-N43 rather than VES500QNDP-20-N43 [#21956221] [#21956282] The thread does not provide a verified firmware file in BIN format; the request for one remained unanswered [#21956382]
  • TV fails to boot despite working backlight and sound
    #1 21956107
    trevorholt1963
    Firmware request for JVC TV model no. LT50CF890(C). Main board Vestel 17MB170. Panel VES500QNDP-20-N43 manufactured in 21/22.
    AI: What is the fault/symptom on the TV - dead, stuck on logo, boot loop, no picture, wrong colours/image, or another issue?
    TV does not boot. Backlight is OK. Sound is OK with terrestrial TV input. No JVC logo on power-on.
    AI: Can you provide the full product code/serial number from the rear label and the current software version, if accessible?
    Model no. LT-50CF890(C), serial no. 8648891 100228.
    Panel model no. VES500QNDP-20-N43.
  • #2 21956133
    flinc
    Level 30  
    Help: 93
    Rate: 156
    On elektrotanya.hu – type ‘Vestel’ into the search box
  • #3 21956221
    yokoono51
    Help: 176
    Rate: 321
    Panel VES500QNDP-20-N43. NO. The panel is VES500QNDP-2D-N43
    I have this
    17MB170 panel VES500QNDP-2D-N43 Finlux
  • #4 21956282
    flinc
    Level 30  
    Help: 93
    Rate: 156
    Enter VES500QNDP-2D-N43 or just VES500
    On Wgoo.....e, search for ‘TV Finlux software’. As on elektrotanya.hu, use the SM SEARCH function for ‘TV Finlux’
    The VES......N43 should be in the Finlux TV service manuals
  • #5 21956308
    trevorholt1963
    Can you please share the firmware file..
  • #7 21956346
    flinc
    Level 30  
    Help: 93
    Rate: 156
    General servicing of JVC LT TVs
    • jvc_lcd_tv_troubleshooting.pdf (5.82 MB) You must be logged in to download this attachment.
  • #8 21956351
    flinc
    Level 30  
    Help: 93
    Rate: 156
    POWER Supply
    • jvc_power-supply_training-manual.pdf (1.79 MB) You must be logged in to download this attachment.
  • #9 21956382
    trevorholt1963
    Thank you, but could you please provide the firmware file in *.bin format?
  • #10 21956405
    flinc
    Level 30  
    Help: 93
    Rate: 156
    Search for ‘bin’ on the Windows.com website
    Right-click the ‘bin’ file – select ‘Properties’ – then ‘Change’
    As a general rule, when you right-click any file, various options are available to choose from
