Hello everyone,
I have a Cecotec 55" QLED TV that is stuck in a continuous bootloop. Before crashing, the system showed an "out of storage space" error. It was triggered by a brief power outage (possibly interrupting a background update) and now it won't access the main menu or respond to the physical power button reset method.
I need the USB recovery software (upgrade_loader.pkg) to force a clean installation.
Here are the exact specifications from the back sticker of the TV:
Brand / Model: Cecotec V1+ Series VQU11055+S QLED 55
Mainboard: Vestel 17MB185
Vestel P/N code: 10139724
Serial Number: 8927452 200494
If anyone has the working dump or compatible USB firmware for this specific Vestel code (10139724), I would be extremely grateful.
Thank you so much in advance for your help!
AI: Can you also provide the panel/display sticker information or panel code from inside the TV, if accessible? A photo of the panel sticker and mainboard sticker would help confirm firmware compatibility.
I cannot open the TV chassis to check the internal panel code, but the external back sticker shows Vestel P/N: 10139724 and S/N: 8927452 200494. This batch uses a 55" QLED display.
AI: Do you know the original software version shown before the bootloop, or can you describe exactly what appears on screen during startup and which USB recovery/reset methods you have already tried?
It runs the original Cecotec Android TV software. The TV is stuck in a bootloop after an "out of storage space" error triggered by a power outage. I already tried the physical power button reset method, but it fails to enter Recovery mode.
