Toshiba 32LL3A63DG 17MB211S - black screen, green LED off, SPI/NAND firmware dump?
ea3fzo 45 0
  • Seeking SPI/NAND firmware dump for Toshiba 17MB211S
    #1 21959138
    ea3fzo
    Subject: Firmware/Dump needed - Toshiba 32LL3A63DG, chassis 17MB211S - Black screen, LED shuts off completely.
    Hello everyone,
    I'm repairing a Toshiba TV and need help finding the correct SPI flash dump / USB recovery firmware.
    **TV Model:** Toshiba 32LL3A63DG.
    **Mainboard/Chassis:** Vestel 17MB211S.
    **Panel code:** [PENDIENTE - completar con el código exacto de la etiqueta del panel LCD, ej. VESxxxWNDx-2D-Nxx].
    **Serial number:** [PENDIENTE - completar con el número de serie completo del TV].
    **Memory chips on board:**
    - SPI flash: 25L1606E / MX25L1606E (16 Mbit).
    - NAND flash: TC58NVG2S0HTA00 or TC58NVG2S0HTAI0 (4 Gbit).
    **Symptom:**
    Screen stays black. Standby LED blinks green briefly, then turns off completely (does not return to red standby). Same behavior occurs when powering off via remote.
    **Diagnostics already performed:**
    - Swapped the power supply with a known-good PSU (tested working on another Toshiba unit with 17MB110P board) - confirmed the PSU itself is not the fault.
    - LED still shuts off completely even with backlight and LVDS panel cable fully disconnected - ruling out backlight as the sole cause.
    - Suspecting either a corrupted SPI/NAND firmware or a short-circuit fault on the mainboard.
    I would greatly appreciate:
    1. A working SPI flash dump (25L1606E/MX25L1606E) for this exact model/panel combination, or
    2. The complete USB recovery firmware package (shredder_usb_update.bin, shredder_usb_update.scr, shredder_usb_update.scr.core, upgrade_mb211.bin) matching this model.
    Thank you very much in advance for any help!
