HUB vs SWITCH: Key Differences in Device Functions for Computer Science Homework
Kristof575 41979 2
  • #1 2329119
    Kristof575
    Hello:] I have homework in Computer Science;] I do not see any major difference between these devices;] Thank you for your help, best regards;]
    Moderated By jankolo:
    I moved the topic from the Software Computers department
  • Switch forwards frames selectively; hub broadcasts to every port
    #3 7780589
    anek7
    Rate: 14
    The main difference, however, lies in the operation of Switch and Hub. Well, the former works in the second layer of the OSI model (data link), its task is to transfer frames between segments. So the switch remembers on which port a given computer is located and transmits information to it, and not to all devices in the network.
    The Hub, on the other hand, works on the first layer of the OSI (the physical layer), copying, amplifying and sending the signal from one computer to all others connected to it. This causes a lot of traffic on the network and therefore a decrease in its performance.
