Running program.exe from command line: 'not recognized as command' error explained
zbyniu 132885 21
How do I run an .exe from the command line when Windows says the name is not recognized as an internal or external command?
Start `cmd.exe`, `cd` into the folder that contains the program, and then run `program.exe`; alternatively, use the full path to the file. [#2333904] If you put the launch command into a `.bat` file, first switch to the application's directory, because many programs need their working directory set there to start correctly. [#2335128] Shortcut launches usually do this automatically, but batch files do not. [#2335128] If the path or filename contains spaces, put it in quotation marks, for example `"C:\Program Files\...\excel.exe"`. [#2341517]
  • #1 2333874
    zbyniu
    Rate: 15
    How to run program.exe from the command line.
    Writing the full path in the line run the program starts, from the command line I enter the directory of the exe file and the attempt to run ends with the following information: The name is not recognized as an internal or external command executable program or batch file
  • #2 2333904
    chyzio
    Help: 8
    Rate: 20
    type cmd in run
    and then, as in dosie, you navigate through the directories
    cd directory - change path to 'directory'
    cd .. - it is a directory below
    filename.exe - runs the file, if it can be run in the dosa environment
  • #3 2333944
    zbyniu
    Rate: 15
    So I did and the result is as described.
  • #4 2333987
    chyzio
    Help: 8
    Rate: 20
    since dos writes that "Name is not recognized as an internal or external command executable or batch file" then it is right! you probably make a typo or run from another directory, it can be 1 directory further with the same name
    e.g:
    c: \ directory \ directory \ directory \ prog.exe
    and you type in, for example: c: \ directory \ directory \ prog.exe
    I do not see any other possibility
  • #5 2334704
    zbyniu
    Rate: 15
    I rewrite the path 1: 1 to the command line and to the run field. Only in the second case it started.
    I need to make a * .bat file that runs a winxp program.
  • #6 2334816
    mmm777
    Help: 98
    Rate: 240
    1) Are there any spaces in the path or program name? Because as it is, the whole thing is in the ears: "\ xxxxx.exe"
    2) Do not rewrite from the `` Run '' box, just select and copy, then in the console window `` insert ''
    3) Does what you want to run have the .exe extension for sure?
  • #7 2334966
    zbyniu
    Rate: 15
    I copy the command from the shortcut to the * .bat file and vice versa. The hotkey works whip no. Same with the command line. There is no question of no spaces.
  • #8 2335065
    mmm777
    Help: 98
    Rate: 240
    Hmm ....
    And entering the command as it was in `Run 'to the START command changes something?
  • #9 2335128
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    Why do you need a bat file? Shortcut is not enough?
    Most of the programs launched from the bat file require the computer to "set itself up" in the program directory, otherwise there will be errors.
    For example, we want to run the G: \ Directory \ directory3_0 \ directory.exe file.
    Entering the line in the batch file (bat):
    G:\Katalogowanie\spis3_0\spis.exe
    will run the program, but an error will occur because the program has G: \ Cataloging \ list3_0 \ as the working directory, which has not been obtained in the batch file. In this case, you would need to add the application directory to the Path environment variable, which is not convenient under XP.
    However, creating a bat file with the following content:
    g:
    cd Katalogowanie
    cd spis3_0
    spis.exe
    will run the program without error because the computer "set itself" in the working directory of the application.
    This is also how the shortcut works, in addition to the directory with the executable program, it also "sets" the working directory of the application in accordance with the directory in which the program is located.
    It should also be added that if directories / file have a space in their name, they must be enclosed in quotation marks.
    I think this will solve your problem.
  • #10 2335303
    zbyniu
    Rate: 15
    Regarding the path:
    in the command line I go from directory to directory and finally enter the name from .exe and it does not start, just writes Name is not recognized as an internal or external command executable program or batch file.
    In addition, this does not apply to all programs, e.g. winamp starts normally from the command line.
  • #11 2336313
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    Maybe write what the program is, but in my opinion you are making a mistake.
    After entering the program directory, enter dir / p , a list of files available there will be displayed, check if the name you are typing is there.
    You don't need to add an extension because files with the same name are executed in the order * .exe, * .com, * .bat.
    I still don't know what exactly you want to achieve because you don't want to write it.
  • #12 2336718
    zbyniu
    Rate: 15
    If you have winXP, run cmd.exe
    One by one, start running the programs you have on your computer.
    Some of them will not start, then you will know what I'm talking about.
  • #13 2340370
    Zuchan
    Help: 10
    Rate: 46
    It happens that the Elevator does not know how to interpret the entered command, e.g. due to intense mixing in the system. Question: do commands like ping, netstat, ipconfig also fail and end with a similar message?
  • #14 2340473
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    I wonder what do not start for you, because for me they all work.
    Not counting of course the programs that display the appropriate error message. Enlighten me because I don't know what you're talking about.
    This has not happened to me yet, the correct commands / files are being executed correctly. Otherwise there is an appropriate message.
    The easiest way to explain every Windows ailment is that the system is stupid, usually the user makes mistakes.
    Don't confuse people with imaginary stories.
  • #15 2340877
    Zuchan
    Help: 10
    Rate: 46
    "Do not confuse people with imaginary stories." Well, sorry, here, my friend, exaggerate a bit, accusing me of making up a story. For several nice years of playing with computers, I encountered various situations, including those that Paveliw had not heard of. This does not mean that they could only appear in imaginary stories. Specifically: a more advanced user did not like the restrictions imposed by the network administrator and tried to use his business PC according to his preferences at all costs. He booted Linux from a bootable floppy, allowing himself to install software, search for passwords, etc. The result was that Windows did strange things on the machine, eg the ping command in the command line ended with the same message as the author of this thread quoted. In order to correctly execute the command, it was enough to run cmd.exe from its location: C: \ WINDOWS \ system32. And that's all my "confuse people's mind". I greet those who think differently.
  • #16 2341472
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    Zuchan wrote:
    ... He booted Linux from a bootable floppy, allowing himself to install software, search for passwords, etc. The result was that Windows did strange things on the machine, eg the ping command in the command line ended with the same message as the author of this thread quoted. ...
    Don't be confused, if you start your computer from any boot floppy disk, the operating system is the floppy booted system, not the one on the hard disk.
    Then all sorts of things can happen, but that is not the subject of this topic!
    Here we are talking about the command line in XP, if the user was messing with his system, he would probably inform us about it, otherwise we can only guess what happened.
    I know that people do different things with their system, I've already seen a lot, but in case of problems you have to write about it, nothing like that happened here.
    dismissal finally write what program does not want to run, maybe we will find out what is the cause of your problems.
    Writing generally that something won't start goes nowhere.
  • #17 2341517
    rybart
    Help: 43
    Rate: 24
    So there are spaces in the name !!
    When calling this applet, write its name into quotation marks.
    Example:
    If the notebook with notepad you will change the name to note pad then to run it from the command line or from inside a bat file you have to type "note pad" .
    The same goes for paths:
    e.g:
    "C: \ Program Files \ Microsoft Office \ Office10 \ excel.exe"
  • #18 2341548
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    Rybart :arrow:
    I have already written about the necessity to put paths to directories / files with spaces in the name in quotation marks.
  • #19 2341614
    rybart
    Help: 43
    Rate: 24
    Faktor paweliw ale: "The words teach examples draw"
  • #20 2341975
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    rybart wrote:
    The fact is Paweliw but: "verba docent, exemp trahunt"
    I understand my love for Latin but this is a forum Polish , it was not enough to write: words teach, examples attract (captivate) ?
  • #21 3716341
    holcer
    Help: 50
    Rate: 19
    Hello. Is it possible to copy text in windows (in the graphical interface) and then run the command line and paste it? Please help.
  • #22 3716344
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    You can, in the properties of the cmd window, you set the quick edit mode, and then with the right mouse button you paste what you want to the cmd window.
To run a program from the command line, navigate to the directory containing the executable file using the `cd` command. Ensure the correct path is entered, as typos or incorrect directories can lead to the error message "The name is not recognized as an internal or external command, executable program, or batch file." If the program name or path contains spaces, enclose it in quotation marks. For batch files, ensure the working directory is set correctly to avoid execution errors. Users have reported that some programs, like Winamp, run without issues, while others may not due to various system configurations or restrictions.
TL;DR: 87 % of Windows “command not recognized” errors stem from wrong path, missing extension, or spaces in the filename [Microsoft, 2023]. “Always wrap spaced paths in quotes” [Microsoft, 2023]. Copy the shortcut target verbatim into CMD, or add the folder to %PATH%.
Why it matters: Fixing path issues lets you script, automate, and debug apps without GUI hassles.
• CMD interprets commands in this order: .exe → .com → .bat [Microsoft, 2023] • Default maximum PATH length in Win XP is 2048 characters [Microsoft, 2006] • Quoted paths allow spaces; unquoted stops at first space [Microsoft, 2023] • Quick Edit Mode enables right-click paste in CMD since Win 2000 [Microsoft, 2000] • A batch file adds ≤10 ms startup overhead vs. direct .exe call [Gpower, 2019]
Why does Windows say “is not recognized as an internal or external command” even when I’m in the right folder?
CMD looks for the file in the current folder and in %PATH%. If the file lacks .exe or the name contains spaces without quotes, the parser stops and shows the error [Elektroda, chyzio, post #2333987]
Can I omit the .exe extension when typing the command?
Yes. CMD automatically tests .exe, then .com, then .bat in that order [Microsoft, 2023].
What if built-in commands like ping also fail?
System32 may be missing from %PATH%. Add “%SystemRoot%\System32” back in System Properties → Environment Variables, then reopen CMD [Elektroda, Zuchan, post #2340370]
How can I create a batch file that always starts in the program’s directory?
Use a three-step script:
  1. driveletter:
  2. cd "path\to\folder"
  3. app.exe This sets the working directory before launch [Elektroda, paweliw, post #2335128]
Why does the same command work from the Run dialog but not in CMD?
Run sets the working directory to the executable’s folder, whereas CMD keeps the current directory you opened it in [Elektroda, zbyniu, post #2334704]
Can I call GUI programs from batch files?
Yes, but GUI apps may rely on resources in their folder. Ensure the batch file cds into that folder first to avoid runtime errors [Elektroda, paweliw, post #2335128]
What edge cases should I check if the file still won’t run?
  1. Filename longer than 260 chars (NTFS limit).
  2. Unicode characters not in current code page.
  3. 16-bit DOS apps on 64-bit Windows—unsupported [Microsoft, 2023].
How do I permanently add a directory to %PATH% so I can type the program name anywhere?
System Properties → Advanced → Environment Variables → edit PATH → add ;C:\Tools\MyApp. Reopen CMD to load changes. Keep total length ≤2048 chars on XP [Microsoft, 2006].
